RUF/Chevy 63s (85 4runner)
Old 08-02-2010, 01:51 PM
SpecialScottie's Avatar
Finally finished with my RUF and chevy 63 swap. Went from a rancho 2 inch lift and 3 inch body lift to RUF and 63's with no body lift. Rides a whole lot better. Also got my 35s mounted. Just need some new shocks now. Here are the pics
Old 08-02-2010, 02:01 PM
yotamonsta-'s Avatar
looks good man!!! quick question did you use stock chevys or lifted??? im looking at doing chevy in the rear but im useing 5" SAS for front and want it to match thanks!!!!
Old 08-02-2010, 02:44 PM
phildelfino's Avatar
Let's see a couple with it relaxed on the ground.
Lookin good with all that flex.
Old 08-02-2010, 06:20 PM
I have stock chevys in the rear. I have a really long shackle though. Its 8 inches eye to eye. With a allpro 5 in the front youd need some blocks in the rear to level it out
Old 08-02-2010, 06:25 PM
toyNG's Avatar
looks awesome! that is some impressive flex!!
Old 08-02-2010, 08:30 PM
Thanks! Cant wait to get it out on the trail
Old 08-03-2010, 12:02 PM
rattlewagon's Avatar
Did you move your rear spring hanger?
Old 08-03-2010, 12:11 PM
Yup. Hanger was moved 11 inches forward and shackle hanger was moved 3 inches back
Old 02-07-2011, 04:33 PM
Bugzman's Avatar
been admiring you truck for a while now, so much so im doing my own chevy swap in the rear, so i have a few questions about your rear set up. mostly about shocks, which ones you used? how did you mount them, what kind of travel are you getting? right now i have 15" compressed and 25" outs, and im hoping i can still use them.
Old 02-09-2011, 02:20 PM
Redneck92's Avatar
Looks good but I want to see it on the ground.
Old 02-12-2011, 12:36 PM
94sasyota's Avatar
what leafs did you use to build that front pack? looking to get rid of my TG 3in leafs and go RUF. lets see pics of it on the ground.
Old 02-12-2011, 01:18 PM
Here a few in the desert but the back is a little sagged out from the dirtbike being on the back. I just used two rear leaf packs and made my RUF packs with 6 leafs
Old 04-07-2011, 11:34 AM
idayota's Avatar
looks great. have you been able to get out on any trail or rock yet?
Old 04-12-2011, 05:52 PM
85YotaBoy's Avatar
ok so im basically a newbie to toyotas, what does RUF stand for (most likely a dumb question dont bash tho) and also what springs do you use to do this swap, i bought an 85 yota that was "lifted" 3 inch body and 4 inch suspension and got to digging around to start fixing and replacing stuff and found that the "4 inch suspension" was some ghetto homemade add a leaf in front and rear with replacement shocks basically it made me look and feel like an idiot when me and my buddy found out, but what chevy leafs do you use and what vehicle are they originally from
Old 04-12-2011, 06:16 PM
yoterr's Avatar
check out pirate4x4.com and go to the toyota section..they got a "toyota bible" that has answers to EVERYTHING....but RUF means rears up front..you just basically put ur rear springs up front...not bolt on tho..you either have to move ur front spring hanger forward..or use different rear shackles..
Old 04-12-2011, 06:17 PM
yoterr's Avatar
and to the OP SWEEET lookin rig man i dig it alot
Old 04-12-2011, 06:28 PM
85YotaBoy, here's that link to Pirate 4X4.
http://www.pirate4x4.com/forum/showthread.php?t=775780
Sweet flex with that setup.
Old 04-12-2011, 06:41 PM
85YotaBoy's Avatar
hey i appriecate all the help, ive been lookin around on pirate4x4 but didnt really want to ask that question on there because im sure i wouldve been laughed at ahaha but thanks for the link and usefull information
Old 04-12-2011, 07:29 PM
85YotaBoy's Avatar
ok so ive been reading alot on the RUF and the chevy rears. i completely understand the rear swap it sounds pretty simple how ever i am lost on the RUF post because well theres wayy to many opinions on stuff to do and spring packs and all and i dont think that it was as organized as the chevy rears post. anyways i have an 85 toyota pick up and want to know how to do the RUF. it seems like everything on the RUF on pirate is 4runner guys talking, Does all that translate to a pickup please explain i want to do this and that write up is confusing
Old 04-13-2011, 09:32 AM
Bugzman's Avatar
85 4runners have almost exactly the same truck as the pickup. they just look different on top. but underneath they are identical.
RUF is a harded to do then the chevys, because you have steering and limits space to move mounts forward, most people will buy a lift kit for the front. but those are pricey and can ride like a poop. RUF is for the guy with a little bit of fabrication ability to get more flex and a little bit of lift for very little cash.
63 chevys has some options too. like scotty ( the guy who started this thread ) is running on a 2 pack, while i have a 3 pack in on my pickup. its all about opinion.
go grab some springs from the junkyard. spend day cleaning them up. and throw them under the truck. you dont like the way they ride, pull them back out switch up the packs throw them back in.
Happy fabbing!
Quick Reply: RUF/Chevy 63s (85 4runner)
