RPMs with 36's and 4.88's vs 5.29s?
Old 04-21-2007, 08:47 AM
Rcross's Avatar
Originally Posted by UKMyers
If you can cruise in a Toy with 36's at 75mph your da man!!! I am running 37's with 5.29's and if I hold it on the floor in 4th gear for about 5 minutes I think I might be able to hit 75. I cruise at around 65 as long as it's perfectly flat and there's no head wind. This is with the 3.slow btw. Would be a different story with the 3.4 I suppose.
What condition is your 3.0 in? Im running 35's with the stock gearing and can hold 70-75 no problem on flat land in 5th gear. In hilly terrain I have to use 4th but can still maintain 65-70 with no issues unless its a really steep hill
Old 04-21-2007, 09:16 AM
UKMyers's Avatar
It runs strong and has in intake, exhaust, electric fan, ect. I could run at 75 if I really wanted to but I'm not gonna run my 3.0 at 4 grand down the freeway. I'm running 3000 rpms at 65 in 5th gear with 5.29's. Anything above 3 grand on the tach and gas mileage drops off exponentially.
Old 04-21-2007, 09:21 AM
Rcross's Avatar
Ok that makes sense, I was wondering with that gearing it should have plenty of power. And I agree with you after 3000 rpms you can almost watch the fuel gauge start dropping off.
I think at 70mph I'm turning about 2100 rpms, its kind of hard telling exactly without using a GPS to get my exact speed.
Old 04-21-2007, 01:30 PM
AH64ID's Avatar
Not to contradict what you see, but does that take into account your speedo error? Doing the math on those tires(569 rev/mile = 35.4 rolling dia), tranny, and gears you should be at 71mph at 3000rpm, and 65 is 2740rpm...
Originally Posted by Stomis
Hmmm alright looks like I'm gonna go with 4.88's then.
I think thats too high, you will be geared higher than stock, then take into account the tire weight and your performance will really be horrible...
For your original post of 2500 at 75 you would need 4.10's... 4.88's will be 3000 at 75 and 5.29's will be 3275.... But how often will you be driving 75 with 36's? I really think you will prefer the 5.29's at everything but 70mph +.
Old 04-23-2007, 02:03 PM
  #25
Joshs98Runner's Avatar
Ah alright see I wanted someone to tell me whats right with rpms because I used to have a commuter v8 that ran like 1800rpms at 75. I guess I'm gonna go with 5.29's then.
I feel you, my mustang put out 307hp at the wheels and 315 tq. I used to cruise 85mph @2400 rpm and barely feather the throttle at all and receive 25mpg. These trucks come with 4.10 gears stock for a reason, the torque isn't there.
Old 05-09-2007, 07:38 AM
  #26
monkeynuts's Avatar
i could not find an answer to this anywhere else, so maybe someone here knows.
my 2000 3.4l 4runner has the 4.10's i believe, and i am moving up to 35's right now. i want to regear, and keep as close to the stock gear ratio as possible. does anyone know which will be closer to stock between the 4.88's and the 5.29's when running the 35's?
Old 05-09-2007, 07:41 AM
  #27
4Crawler's Avatar
Try:
- http://www.4crawler.com/4x4/4LoCalc.shtml#GearRatio
Old 05-09-2007, 07:56 AM
  #28
monkeynuts's Avatar
perfect, thanks!
justdifferentials
Just Differentials
06-13-2022 07:40 PM
justdifferentials
14
06-11-2017 08:36 PM
Mrfobbyaccent
09-10-2015 12:13 PM
justdifferentials
09-05-2015 06:52 PM
AkitaDog
09-03-2015 09:01 PM
Quick Reply: RPMs with 36's and 4.88's vs 5.29s?
