need to make the 94 offroad worthy on 200 bucks, but how? street legal not an issue
hey all, gonna make the 94 offroad ready and "capable" now that i have the taco, what should i do for 200 bucks, thinking 3" body lift, now sway bar, torque torsion(just a little bit though) and mabey weld up the rear end. to get the truck to the trail, i plan on using a tow dolly, but if the truck has a lincoln locker, will i be able to, i was thinking just tow it backwards but dont know anything about tow dollys. anyways whats cheap, but worth doing to make the truck better offroad, remeber only have 200 bucks, thanks
wade
wade
weld front and rear diffs, just dont flat tow it, a dolly will work good enough. spend more than $200, and get a cage. i know you said just 200, but this will be the most important mod, this way you can wheel the piss out of this truck, and not really worry.
sawzall all fender openings, remove the sway bar completely, cut down your existing bumpstops, and in a while, get a set of used 33's or 35's from your local paper for dirt cheap.
if you do this, and are obviously not afraid of body dammage, you can run alongside just about everything.
ok from what you said this is what will be completed in the next 4 days, grind all fender openings that rub, already has 32X11.5's if i have to sawzall so be it, (ill borrow one from someone i guess, i dont own one ) then im gonna give the rear a lincoln locker but not the front, (wanna be able to turn) the swaybar will be taken out tommorow. the cage will come later, for now just a bar. thanks
later
wade
later
wade
Downey HD rear springs, crank torsion bars, remove sway bars, UK Myers airbox mod, and weld the rear diff. Welding the front will make steering next to impossible in tight areas on the trail. Everything is free except the springs.
Guest
Like Victor said, don't weld the front. Besides making steering impossible...you will break a CV for sure.
I don't want to sound like a "mom" but be sure and take it easy while you wheel. 4x4-ers don't need more stuff to give them a bad rap. $200 certainly isn't enough to make it an awesome rig, but a few key things could get you on the right track. If you are serious about wheeling, you'll drive it like you intend on driving it for the next 20 years.
Don't just be another shot-up old beater that's abandoned on the trails.
Jim
Jim
If you go with manual hubs then you can weld your front diff and still turn. You just have to get out and unlock one hub when you want to turn, could be a pain in the butt, but people do it. People also say you tend to break fewer CVs when you're locked up front because you can do obstacles slower. Either way, you should be carrying an extra CV.
Originally posted by Victor
UK Myers airbox mod
UK Myers airbox mod
Lose the swaybar, weld up the rear end (weld the spiders together, DO NOT WELD TO THE CAST METAL), and trim any sheetmetal that rubs. Body lift if you really want, but remember the more you do the harder and more expensive it'll be. I'd just do 1-2" if I were you. Then save your money for safe well thought out non-half-assed mods down the road.
Originally posted by Shane
I'm assuming this is the same deckplate/swiss cheese holes type of mod? Not a good idea up here in the NW, we have this annoying substance called water that tends to be deep in places...
well, i plan on taking the 200 and doing this with it.
first thing is repair my blown head gasket i just found out with, cost, 50 $
now im at 150
next, weld the rear diff. cost free
still at 150
next i plan on buying a snorkel ie: go to lowes
cost, 40. (probably to much but hey i like to plan big!)
leaves me at 110.
removing all unwanted sheetmetal free
removing swaybar free
body lift it outta the qestion. (higher center of gravity)
the rest of the 110 will be split into 2 catagories.
55 to the bank
and ill away the rest.
just kidding. ill probably save the money for gas and just in case stuff happens.....sad to say though i dont see myself making it to pnwyj.....to little time to lil money! anyways, im gonna try, any other ideas on what i could do let me know. free is me.
wade
now im at 150
still at 150
leaves me at 110.
55 to the bank
wade
Well just got back from my local shucks, got a new head gasket, and everything i need to put it on for 44 dollars, im gonna put that in and hope everything works. and theres a 70/30 chance i will still be going shane, things just aint looking to hot right now to say 100%
but does anyone have any ideas how much it is to rent a tow dolly somewhere? i dont have a trailer or dolly yet!
and also, if i weld my rear end, will i still be able to pull it without a trailer (IE: tow dolly) or what? thanks
wade
wade
06-01-2021 01:51 PM
09-04-2015 09:27 AM
FS[NorAtl]: 1989 pickup beds and leer cap Rhode island
mickyd9990
07-06-2015 09:01 AM
