Hemi jiont TRE's
Old 02-07-2009, 04:20 PM
LTrunner's Avatar
Talking Hemi jiont TRE's
i did some sreaching and couldn't find any, or any info on hemi TRE jionts.so i'm making this thread for idea slinging...
now i can find hemi jionts of different sizes, and spacers to fit, they come in left and right hand threads. you would just need to buy the right hardware. i think the hemis would be stringer than regualr TRE's and they have nearly unlimited swivle for felxing.
so would they be good, or bad?
but anyways let the ideas fly
Old 02-07-2009, 04:23 PM
algranger's Avatar
what's a hemi joint?
Old 02-07-2009, 04:25 PM
LTrunner's Avatar
http://www.trail-gear.com/images/2008-1576-600.jpg
TG sells "creeper jionts" but they are hemi jionts, many other places sell them too
Old 02-07-2009, 04:30 PM
algranger's Avatar
oh ok, i googled it and got a bunch of pictures of cut open feet and stuff i was like
so what's a TRE joint?
Old 02-07-2009, 04:32 PM
LTrunner's Avatar
Tie Rod End
Old 02-07-2009, 04:33 PM
algranger's Avatar
duh!
sounds like a good ideer but do your really have that big of an issue with your stockers?
Old 02-07-2009, 04:36 PM
LTrunner's Avatar
when i SAS i want to use the hemi's BUT...there isn't much info of how they perform/work. thus this thread
Old 02-07-2009, 04:38 PM
algranger's Avatar
i see. well i dont see anything wrong, sounds like a good ideer. but as you can tell i just learned about this mod so i'll just sit back and wait for someone else to chime in.
Old 02-07-2009, 06:37 PM
tc
tc's Avatar
They're called HEIM joints - that's why your search didn't find anything.
Typically, they are used for trail only trucks as they have quite a bit more slop and play than a standard TRE.
Old 02-08-2009, 12:22 PM
LTrunner's Avatar
they have more slop...seems like they would have less to me. i know alot of jeep guys running them without much slop...and i think they would last longer
Old 02-08-2009, 07:37 PM
4rnr's Avatar
Ok, well thats not a heim joint its an RE joint or Johnny Joint. If you mean using an RE as a steering link, I guess it could work, my concerns would be running a joint like that in a single shear style mount. I dont think it would be safe or very positive feeling. Also they require rebuilding as they wear.
If your talking about heims? Then I always advise against heims for ON ROAD use. Unless your truck is a trailer queen then you will likely find that in little time they will wear out and feel sloppy and dangerous.
I say they are both bad ideas. Whats wrong with a fj80 TRE, they are strong as hell.
Old 02-09-2009, 02:34 PM
LTrunner's Avatar
nothing's wrong with the fj80 TRE's i just wanted to get some ideas on the heim/jonny jiont/re JIONT tre OPTIONS...there is not much iinfo out there that i could find
Old 02-09-2009, 02:42 PM
4Crawler's Avatar
I've run heim joints on my steering for at least 10 years now, they work fine for me:
http://www.4crawler.com/4x4/CheapTri...ng/index.shtml
I have mine set up now with the bolts in double shear for added strength:
http://www.4crawler.com/4x4/CheapTri....shtml#HySteer
Old 02-09-2009, 02:54 PM
tc
tc's Avatar
You must suck at the then ...
Here's info on Johnny Joints, give you a good idea of the strengths and weaknesses of heims too:
http://www.currieenterprises.com/ces...nnyjoints.aspx
I have JJ on both ends of my rear 4 link and they are NIIICE - move SUPER smooth with NO binding.
RE joints are basically the same thing:
http://www.rubiconexpress.com/Builde...px?part=RE3791
Old 02-09-2009, 03:06 PM
4rnr's Avatar
Have you been doing alot of street driving on those joints over the ten years? have you ever rebuilt them? I see you are in the SW, here in the Midwest the mud tears up heims in no time. We dont even like to use them on suspension. If I linked I would use bushings at the axle and RE/Johnnys at the frame, if not rubber all around. But then again my truck sees a lot of sloppy trails and alot of highway.
BTW I like the double shear!
Old 02-09-2009, 03:30 PM
85excab's Avatar
ive got a few friends who run hiem steering. they run the Qa1 3/4 x 3/4 hiems. and they havent had a problem yet. and i'll put money down on a qa1 hiem being stronger than a fj60 tre. ive worn out 3 so far.
Old 02-09-2009, 07:47 PM
4rnr's Avatar
Not a question of strength, its a question of road manners.....
Old 02-12-2009, 11:47 PM
Matt16's Avatar
Hemi joints....
Old 02-26-2009, 09:47 PM
son_of_a_lc's Avatar
I agree
Hiems are great for trailer qeens, but for a daily driver, over time especaily, they would wear out and get really sloppy and noisy. No bueno.
Old 02-27-2009, 05:48 AM
meswoleshane's Avatar
What axle is that? looks like a toyota 8" with D60 ends grafted on it?
Quick Reply: Hemi jiont TRE's
