YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Off Road Tech, Fab Shop, Solid Axle Swaps, Tool Time, & Engine Swaps > Offroad Tech
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 05-23-2008, 05:25 PM   #1 (permalink)
ozrunner's Avatar
front lockright. is this normal?
Sorry if it's a bit rude posting a question as my first post but I'm slightly worried about this locker.
I've just installed a lockright locker into my 1986 4runner. I have a mechanical mind and found the install to be fairly easy and I'm pretty sure I did everything right.
When I went for a test drive I found the locker would unlock sometimes (resulting in normal steering) and not unlock other times (severe understeer and super hard to turn the wheel). I was driving slowly in 1st/2nd gear in high ratio 4WD on a road and on some dirt. The problem was worse on the road.
Is this normal for on a road, and in the bush its less noticeable?
Thought I should add: I had researched this before the install and was expecting irregular steering... just wasnt expecting NO steering!
ozrunner is offline
Sponsored Links
To remove this ad, register today!
Old 05-23-2008, 06:02 PM   #2 (permalink)
EWAYota's Avatar
Send a message via AIM to EWAYota Send a message via MSN to EWAYota
Driving on high-traction surfaces (street) with 4 wheel drive alone isn't a good idea, could lead to binding and other issues. With a locker that should be magnified.
I'm sure others will chime in on what exactly is going on but your steering should be hampered with a front locker on a street.
Offroad though, it will handle differently.
__________________
DJ
1994 Pickup
22RE, Engnbldr 261 cam, 5 speed. Tires that go around and around...
Originally Posted By Fustercluck
"Proof that Gangus did not spontaneously generate....he has relatives."
Originally Posted By Tacoclimber
"My two year old better get a job, soon..."
Reply Posted By Oly884
"I hear coal mining is a great career."
Myspace
EWAYota is offline
Old 05-23-2008, 07:09 PM   #3 (permalink)
seafarinman's Avatar
Send a message via AIM to seafarinman Send a message via Yahoo to seafarinman
Is this happening in 2WD or 4WD? I have a V6 lockright in my front axle but I have a solid axle. I think that it would be silly to install one in a 7.5" IFS front diff.
__________________
Rome the "Seafarinman" IT1(SW) US NAVY
1994 SAS 2RZ/R151F=244:1!
http://s11.photobucket.com/albums/a176/seafarinman/
seafarinman is offline
Old 05-23-2008, 09:31 PM   #4 (permalink)
ozrunner's Avatar
I am aware that 4wd isnt made for street but like I said, I was testing the locker to make sure it locks and unlocks correctly. If this is normal for on road thats great. I was just a bit worried and wanted to check.
Sea, why would a locker in a 7.5" be bad?
ozrunner is offline
Old 05-23-2008, 09:43 PM   #5 (permalink)
DeathCougar's Avatar
Send a message via AIM to DeathCougar Send a message via Yahoo to DeathCougar
Welcome to the wonderful world of lockright. The things you are encountering is the very reason I am yanking the lockright out of my 87, and installing a spool.
The locker in the 7.5" isn't really the worst idea ever, but dont plan on super hardcore wheeling. Otherwise you will be breaking stuff. Lockers=breakage.
__________________
Need that hard to find part? Nix99 Used Toyota and Lexus parts!
Quote:
Originally Posted by Junkers88 View Post
Good lord this thread is like herpes. Everytime I think it's gone there's another outbreak.
Quote:
Originally Posted by Sin91
If i am awake, I am horny; ask Abe!
DeathCougar is online now
Old 05-24-2008, 01:03 AM   #6 (permalink)
ozrunner's Avatar
I found some dirt/mud/gravel etc. and the locker was fine. I guess I shouldnt have expected much from a road. Thanks.
ozrunner is offline
Old 06-01-2008, 07:11 PM   #7 (permalink)
86Original's Avatar
I think that is a misconception. It depends on how you drive and if you have manual hubs. I think you're less likely to break a CV w/ lockers because you never have one wheel spinning in the air and then coming down and shock-loading the CV. If you're locked up all around, you're going to have every wheel turning the same speed, unless you're turning and the outside wheels ratchet.
Yes, you will have understeer on solid surfaces (bitumen, concrete, slick rock, etc.) At times you'll have a little understeer on dirt / sand. That's why a twin-stick is looking appealing to me. Next time the T/Case comes down, twin-sticks are going in.
Obviously, with manual hubs, the CVs won't be turning at all when you're in 2WD w/ hubs unlocked. In addition, if you are reasonable with the skinny pedal, everything fares better.
__________________
Original owner: 86 4Runner, Some mods;
Read more here.
86Original is offline
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Front Lockright on ifs-How is it? mtrdrms 86-95 Trucks & 4Runners 15 09-26-2007 12:37 AM
Lockright is installed in the front Victor 86-95 Trucks & 4Runners 3 08-13-2007 06:22 PM
Is this slop in the front diff normal? (vid) ovrrdrive 86-95 Trucks & 4Runners 9 03-08-2007 06:57 AM
selectable lockright for front diff idea! Mr. Bob Offroad Tech 2 03-26-2006 06:53 PM
Lockright in front? colsoncj Offroad Tech 3 02-12-2005 11:50 AM
Advertising - Privacy Policy - Terms of Use - Jobs
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
