Extended Shackle Questions
Old Aug 23, 2008 | 03:45 AM
hellfire's Avatar
I have bought some extended shackles, I am wondering if I need any other mods to fit them.
My truck is 2" lifted shocks and springs, but I want to get that bit extra out of it.
How easy are shackles to fit, and will I need any other parts installed to get them to work, brake lines etc?
Thanks guys
Old Aug 23, 2008 | 06:31 AM
dirtoyboy's Avatar
Thanks guys
well dont u already have a SAS? are you using stock shackles? what is your spring set up?
Old Aug 23, 2008 | 07:51 AM
4Crawler's Avatar
Thanks guys
Shackle installation tips:
- http://www.4crawler.com/4x4/ForSale/...l#Installation
May need to add a shim to the axle to correct the pinion angle, depending on shackle length and drive shaft type:
- http://www.4crawler.com/4x4/ForSale/...es.shtml#FAQ12
Measure for the shocks and brake lines, etc. See if any of them are getting pulled tight at full droop. If so, replace with something longer.
Old Aug 23, 2008 | 02:47 PM
hellfire's Avatar
Thanks for the replies..
The springs I have are leafs, already 2" lifted with standard shackles.
The shackles I have bought are 155mm from end bolt to end bolt
Flying91
45
Apr 11, 2024 04:39 PM
young buck
18
Aug 27, 2018 02:40 PM
Griff
93-98 T100s (Build-Up Section)
Sep 23, 2015 10:11 PM
makemusic116
Aug 2, 2015 05:23 PM
ksmudrunner99
Jul 21, 2015 05:33 AM
