| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Elocker stuck (locked) any suggestions?
#2 (permalink) |
Do you hear the motor turning? If so jack one wheel and turn it with your hands, it has to unlock.
If you don't hear the motor unlocking then your motor brushes must be stuck. It happened to me once with my RR E-Locker and now I've the same problem with the FR one. David
__________________
'94 Toyota 4Runner 3.0 Turbo Diesel Intercooler Auto – Trail-Gear 4'' SAS front, Trail-Gear 5'' rear leaves swap, 35's, FR&RR E-Lockers and too many things more to write... |
#3 (permalink) |
I do not hear the motor turning. After taking it apart and putting back together is it pretty reliable, or should I expect the same problem in the future? I called the dealer this morning and they must have gotten the wrong part because they said the motor alone was $855.00 If anyone has a part number or approx. price it would be appreciated!
#4 (permalink) |
I figured it out! The ECU or switch must have been bad. I just used the relay method and it works beautifully. Sure beats pulling the motor out.
#5 (permalink) |
Either way locked or working, you would have been ready for this weekend
__________________
97 4runner SR5 Locked, Lift, Sliders, 33" Bighorns, 2 TRD stickers 5hp each= 10hp+ 83 Toyota Pickup Shortbed 4x4 Lift, 33" BFG M/T, Lincoln Locker |
| Tags |
| elocker, motor, number, part, stuck |
