| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
E-Locker or ARB locker...Which is better & Why?
__________________
99 Limited 4Runner 4WD ARB Bumper WARN 9500 Winch Hella 4000s My 4Runner Tons of Pics Videos of all kinds of stuff |
#2 (permalink) |
First, welcome to YT!
People here are great and you'll learn a lot! Not that I have any first hand experience but I've heard from a few people that the E-locker is better as the ARB air locker is dependent on the compressor which will sooner or later crap out because of the constant strain of maintaining the air flow. That's what I've heard though, I don't have any experience to back this up. |
#3 (permalink) |
E-locker. The ARB requires constant air to keep the locker engaged. With the E-locker, it is run off of a pulse. It doesn't need constant electricity to run. A pulse engages it. It will stay that way even if the wires get cut.
__________________
New Rig 2007 Double Cab Taco Sold 1991 300ZX Twin Turbo Stage 3+ Sold 1991 4x4 Pickup V6 5spd; 3" Rancho lift; 1.5" BJ Spacers; Rear Detroit |
#4 (permalink) |
I replied to the other thread as well.
I have dual ARB's and love it. ARB rear thirds bolt right in, e-locker thirds require modifications. My ARB compressor is no where near "crapping out" after running the lockers for the last 18 months or so. The lockers require constant air pressure to remain activated, but the compressor has a tank so it does not run the whole time. ARB's engage and disengage quicker. Cost becomes a wash if you are regearing. |
#5 (permalink) |
Are there any aftermarket E-lockers for the 4Runners that are pretty much the same as the OEM one from Toyota or can you buy the stock one? How much does the average install cost?
__________________
'99 4Runner Highlander 4wd E-locker,rear diff and deckplate mod * 265/75/16 Nitto TerraGrapplers * Yakima Load Warrior rack * clear corners/signals * Tacoma skidplate * Silverstar lamps/fogs Alpine CDA-9831,Bazooka EL Series 250w amp,MTX 10" sub |
#6 (permalink) | |
Quote:
I went the used e-locker route versus an ARB because of the price. But if you got a new 3rd with e-locker your about the same as far as money. John
__________________
'97 4Runner SR5 Front: Tundra Coils/Tokico Trekmasters | Rear: LC Shocks & Coils + SS rear "fixes" | Custom Sliders 285/75 Maxxis Bighorn Radials | Retrofit E-Locker | TJM T15 | Custom Rear Bumper | Warn m8000 |
#7 (permalink) | |
Quote:
thanks for the information!!
__________________
#8 (permalink) |
what about the electrac? limited slip when unlocked, and fully locked when engaged. that is what i would buy.
__________________
-Joe Z Chicago 4x4 My Webshots 1985 Toyota 4Runner, 3" Trail Gear rear/ All-Pro front springs, 42x14 IROK's, Allied Rockathons, spool rear/detroit front, 30 spline longs, Dual cases w/4.7, Marlin High steer, lots of other stuff.. 1997 Dodge 2500 4x4, 12valve CTD, not stock. |
#9 (permalink) |
joez-I dont think the electrac is out yet for the toyota 8"
.I would get an ARB so I have an excuse to get a air compressor too
__________________
1997 Toyota 4Runner, 3.4L (5VZ-FE), 5-Speed (R150F), 4WD, 4.10's, 33's 1998 Toyota 4Runner, 3.4L (5VZ-FE), 5-Speed (R150F), 4WD, 4.10's, 33's 1991 Toyota 4Runner 4 Door, 3.4l (5VZ-FE), 5-Speed (R150F), 4WD, 32's, 4.10's |
#10 (permalink) |
This was linked on a virtually identical thread earlier this year:
http://www.pirate4x4.com/forum/showt...ARB+vs+elocker |
#11 (permalink) |
john -
search www.car-part.com for 96-00 4Runners with the e-locker. search carriers with diff lock and whatever gear ratio you want. you can swap the rear third with the modifications. for the front you can buy a 3rd with the ARB and gears set up and just swap that in. at least this is how i would do it. marc z got 4.88s and ARBs put in a month ago from patrick at 4x4customs near his house. paul is getting 4.88s and ARBs put in (maybe he already has them) too. so try to get a hold of them.
__________________
Ryan New: 2008 4Runner Sport. Mild, not wild. Old: 2000 4Runner 305s, Locker, TJM, Warn, Skids, Sliders, SC |
#12 (permalink) |
I forget if it is Electrac or the Eaton E-locker, but one of them got sued by Toyota because the locker they were marketing would be fundamentally identical to the stock Toy e-locker. Because of this, there will never be one of those, I want to say the Eaton one, available for a Toy.
#13 (permalink) | |
Quote:
![]() I'm still curious if anyone has tried Inchworm Gear's "E-Locker control Kit" for $75 "The electric locker control kit contains everything you need to engage and disengage your new electric locker. The switch, wires, relays, resistors, connectors, and zip ties are all included. It's also complete with instructions so you can install it." --From Inchworm's website... www.inchwormgear.com That seems like a fairly inexpensive way to wire it up. John
__________________
#14 (permalink) |
ARB... hands down. It's a stronger carrier. For serious wheeling everybody knows that you choose between a Detroit and an ARB. Nothing else can replace the carrier w/ anything stronger except for a spool.
__________________
1995 Land Cruiser -ARB'd, OME'D, Slee'd, Warn'd, lifted, locked, dented, WHEELED. |
#15 (permalink) |
ARB because they make a cool sound when you disengage 'em.
#16 (permalink) | |
Quote:
__________________
#17 (permalink) |
is the inchworm E-locker just the OEM one?
#18 (permalink) | |
Quote:
As for the $75 kit, you can get everything you need to build a crude control system for around $20. In my opinion if you're gonna spend that much for the electronics you might as well go all the way and use the stock ECUs, they work very well and give you some basic diagnostics info through the indicator light.
__________________
"It's one great big dysfunctional family that now has to split up and spread dysfunctionality around the greater world," Bill Stainton on the breakup of the cast of "Almost Live!" Last edited by Shane; 10-27-2003 at 09:02 PM. |
#19 (permalink) |
How bout a good place to find used elocker, cause they are probably cheaper. I didnt see any decent priced one on car-part.com
__________________
1997 4runner,lifted, locked, dash and grille mounted red LED lights, its my DD 1988 4runner, SAS, dual lockers, dual cases, longfields, 36's, and lots more. |
#20 (permalink) | |
Quote:
Go for it!
__________________
Jay - 97 4Runner SR5 V6 Auto Air/E Lockers, OME, Revos, ARB bull bar, Superwinch X9, sliders, etc . . . |
| Tags |
| 4runner, arb, craigslist, detroit, diff, elocker, harness, inchworm, install, lock, locker, oem, toyota, tundra, wiring |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| QuickAir II & ARB locker (OBA system) | BajaTaco | Offroad Tech | 5 | 07-19-2005 12:58 PM |
| Toyota e-locker or ARB air locker?? | ranma21 | Offroad Tech | 34 | 10-04-2004 09:15 AM |
| ARB air locker or E-locker | george16 | 95.5-2004 Tacomas & 96-2002 4Runners | 5 | 03-18-2004 07:45 PM |
| ARB Locker | george16 | 95.5-2004 Tacomas & 96-2002 4Runners | 3 | 08-02-2003 12:49 PM |
