bud built rear shock mounts
anyone have the rear shock mounts that bud built sells? i need to run much longer shocks and want to angle then diagonally towards the middle of the bed. Budbuilt seems to be the cheapest and easiest i have seen besides custom fabbing something myself. does that kit (upper and lower mounts) come with everything it shows in the pics. the muffler clamps, lower brackets and the upper plate that bolt the crossmember under the bed. I know the instructions say u can buy the muffler clamps locally. does that mean they dont come in the kit. Thanks in advance for any help
Have you heard of Sky-Manufacturing im looking at getting this set up
A rear shock hoop designed to allow shocks to be moved on top of the axle and tilted inward to allow maximum travel. These are designed to use eye mount shocks and are a weld-in item. Constructed of .120" wall 1.5" tubing. Fits all '79-'95 Toyota pickups and 4-Runners. Includes lower shock mounts.
Part # TOY-RSM-001
Price - $60.00
Part # TOY-RSM-001
Price - $60.00
I made my own lower and upper shock mount following the budbuilt design. They work, but you have to tighten the HELL out of them or they rotate around your axle and cross member. If access to a welder, spot weld so that can't happen. Is what I intend to do this spring.
Yotadawgjr
10
08-23-2015 10:51 AM
jon.r
07-11-2015 03:34 PM
FS[NorAtl]: some RC stuff crawler and racer
akaphilly
07-09-2015 02:34 PM
skoti89
07-08-2015 12:05 AM
