Any real pluses for the T100/tacoma/tundra axles?
Old 01-27-2007, 01:50 PM
ryan22re's Avatar
I'm wondering if there are any major pluses to running a newer axle vs. running an 87-95 V6 axle? I know about the pinion size, 27 vs 30 on the newer stuff, plus the girdle, but everthing else seems the same. Am I missing something? Seems like the locker availability is there with the newer stuff.
This would be on a lightweight rig with fullwidth (the only reason I ask) axles. So a T100/tundra axle would be close to ideal. I was planning on trying to make it full floater too, so I guess I could run the narrower 87-95 version and run some wider hubs on it to make up the difference.
Any help would be apprieciated.
Old 01-27-2007, 07:23 PM
Stomis's Avatar
Do you plan to run T100 axles on the stock IFS? I know coupled with a longtravel kit they off alot more articulation.
Old 01-27-2007, 07:25 PM
Flygtenstein's Avatar
A Tundra/T-100 is 67ish. That is a lot to make up from any non-custom Toyota front with just hubs.
Before the new Tundra, this is the best Toyota diff.
The problem with off the shelvers is availability, just not a lot around.
I would run one in a heartbeat, I may yet crossover my custom rear to run the shafts since I need the width.
Old 01-27-2007, 07:54 PM
Sonofmayhem's Avatar
i know a few folks who use the taco axle under their early model trucks, also its 86-95. i would run one, but i can get gears and a locker far less than what ill pay for just the diff from a taco
Old 01-28-2007, 05:39 AM
ryan22re's Avatar
It'll be a solid axle buggy with most likely a 10 bolt chevy front end (cheap and plentiful), so I'll need the width. I was refering to making the 86 (oops)-95 a full floater with some wider hubs to match the front if I were to use it.
I agree that the older stuff would probably be cheaper and easier to find. So thats what I will probably be searching for, unless I come across a smoking deal on a t100/tundra axle.
Thanks for the info guys.
polo451
13
11-20-2016 07:49 PM
Braparus
42
06-30-2016 12:17 PM
Jcrawl94
10
10-24-2015 04:34 PM
Charliegardmn
09-10-2015 08:42 PM
Gravel Maker
RuffStuff
08-06-2015 04:27 PM
Quick Reply: Any real pluses for the T100/tacoma/tundra axles?
