alignment hysteer
Old 04-30-2007, 08:53 PM
Sonofmayhem's Avatar
alignment hysteer
ok, my steering wheel is all sorts of crooked, is there any directions i can get for aligning a tg hysteer kit?
Thanks
Old 04-30-2007, 09:05 PM
Kaleb's Avatar
Just pull off the pitman arm, and rotate it.
Old 05-01-2007, 04:32 AM
Marc P's Avatar
After everything was lined up for me, I ended up pulling the steering wheel off and repositioning it.
2 screws and a big nut.
Old 05-01-2007, 07:01 AM
waskillywabbit's Avatar
Check the SAS tech write up on my website for details.
Basically all the OEM steering is off.
Center the steering wheel by turning the wheel lock to lock and taking note of center.
Attach the hysteer stuff.
The steering wheel should not be off if you measured right
1/8" toe in is what you want for wheel alignment
Old 05-01-2007, 06:36 PM
thanks!
Old 05-01-2007, 07:31 PM
4Crawler's Avatar
See:
- http://www.4crawler.com/4x4/CheapTri...html#Alignment
Assuming the pitman arm is properly centered, do not pull it off and change it:
You can either pull the steering shaft out of the upper clamp and re-center the steering wheel or just pull the steering wheel off and put it back on centered.
Old 05-02-2007, 08:33 AM
Ok, ill just pull the steering wheel, last time some one told me not to.
Old 05-02-2007, 08:35 AM
4Crawler's Avatar
Just make sure to recenter the turn signal cancel cam before putting the wheel back on.
ladybugRC
458
08-21-2020 10:41 AM
stanz
10-30-2015 10:33 AM
voiddweller
09-28-2015 11:21 PM
gyroscope7
09-21-2015 04:55 AM
gyroscope7
09-13-2015 05:15 AM
Quick Reply: alignment hysteer
