4" TG SAS kit w/ OME 3-4" rear lift?
i'm very interested to see what this is going to look like with the sas and 901's+coil spacers. i've been thinking about doing the exact same thing for a long time.........
well, you'll see within a month. I'm starting the swap on july 13th or so. A bunch of other friends are coming over for a wrench fest that weekend.
#25
It will be exceptionally tail low and instead of moderately tail low.
901's with 2.5" spacers will be about the same height as stock cruiser coils.
This will jack up your castor and make the truck a T-rex.
The best rears on these trucks is shown in my pics.
-Stock Cruiser Coils
-Rancho 5009 shocks
-Custom Panhard
-Panhard drop bracket
-Bent link to get around gas tank
-Skinnier driveshaft
The height this gives works well with little to no front lift, not a solid axle.
-Rancho 5009 shocks
-Custom Panhard
#27
-Rancho 5009 shocks
-Custom Panhard
-Rancho 5009 shocks
-Custom Panhard
chimmike i don't mean to hijack i just think we have the same idea here.....
#28
I think what I may end up doing is ordering the 3" springs and hiding my 4" springs in the garage until I properly lift the rear to equivalent levels.
We'll see though, yotasvg, what it looks like with the spacers on 901hd's when I'm done.
#29
good good. i'm putting away lots of dough right now for the 3" spring sas...i'm stoked, but i need to find an axle first........
#31
Please continue to do swap homework.
Everyone on this site has ended up pretty close to the same lift height. The guy who tried to go really low ended up with issues. Regardless of other components, the rest of us are within an inch of eachother.
If the rear is way low, that impacts front caster.
The lower you go, the less compression you have. The less compression, the worse the ride.
The rear shock length and links have the biggest influence on rear flex. Look at those pics. WAY out of the fender well. I was sad to cut that off.
Just go long travel...
#32
if i go long travel, then i don't want 4wd. i'll do that on a different truck.......
so flyg, i'm pretty sure this is obvious, but, i guess i'll just take the better rout and save for the full swap.
kawazx636
10-06-2021 03:03 PM
voiddweller
53
02-01-2016 05:46 AM
Toys4parts
09-26-2015 01:56 PM
