35's and 3" lift on a Tacoma?
Old 03-13-2007, 05:29 AM
copperhead_69's Avatar
My plan is to put 35 inch BFG KM's on my 98 Tacoma with All Pro's 3 inch coilovers and rear lift. I plan on a 1 inch body lift and Bushwacker cut-outs. It will have 35x12.50's on a 17x9 wheel. Besides new gears and steering rack poly bushings, what else could be done to make this stronger or better?
Can this be done without rubbing or any other problems??
And maybe a lockright in the front with my manual hubs??
This is my first lift so I wanna get it right the first time.
Thanks
Old 03-13-2007, 07:16 AM
4Crawler's Avatar
I doubt it without a lot of fender trimming:
http://www.4crawler.com/4x4/ForSale/...it.shtml#FAQ10
Old 03-13-2007, 07:25 AM
tc
tc's Avatar
Check out TTORA.
They're gonna say you need a 6" lift to make 35's work, but if you're willing to cut ...
http://www.trailslesstraveled.com/ar...ny-lift-height
Old 03-13-2007, 05:47 PM
HUTCHSTACO's Avatar
i dont see you having any chance of wheeling it... and still idk... i would stick with 33 with that lift if you plan to drive it
Old 03-13-2007, 09:28 PM
Albuquerque Jim's Avatar
Yes, you can put 35's on a Taco without building a monster truck.
This is my buddy's '04 with Sonoran Steel's 6.0 Lift Kit: which consists of Tundra front lift (2.5" front), a Deaver 3 leaf add-a-pack, Daystar Shackles (3" rear) and all the right accessories. He also added a 2" BL.
The tires are 315 Xtreme AT's on 4" BS 16x8 wheels.
He has had to trim the pinch weld, a little flare and fender, but not bad at all IMO. The only place he still rubs in on the frame at full lock.
Recent Pics: Just added Badlands Bumpers
Before the bumpers, but same lift.
Yes, you can wheel it.
P.S. I run 315's on my 4Runner with a 1" BL and the same front set up. I have trimmed more and still rub slightly on the inner fender under full compression, no biggie though.
Old 03-14-2007, 07:12 AM
4rnr's Avatar
I know its not a Taco
when I was IFS I had 35's on cranked t-bars, and some coil spacers (I would say 1.5-2" of lift.) I had to work the fire wall with a hammer a little but no fender trimming. I could have wheeled it but I used a set of 33" tsl bias ply's which measure 33.7" tall (as tall as some 35's) and I didnt rub with those and it was flexy, in the rear any way.
Old 03-14-2007, 10:41 AM
HUTCHSTACO's Avatar
whats the reason you want 35's
Old 03-14-2007, 01:40 PM
tc
tc's Avatar
Because all the cool kids run 35's! LOL
Old 03-14-2007, 08:57 PM
Why 35's?? Why not 35's?? Come on now, I still have the Indy Front ˟˟˟˟˟ on there. I need help with some ground clearance. Plus, I just wanna show my buddy up in his chevy with 6" lift and 35's
33's with 17 inch wheels just looks funny.
Old 03-14-2007, 09:00 PM
tc
tc's Avatar
If you really want to show him up, put in lockers, leave the rest stock and then outwheel his open/open POS every day of the week...
Old 03-14-2007, 09:34 PM
Flygtenstein's Avatar
Come on, please don't fib.
Old 03-14-2007, 10:13 PM
AxleIke's Avatar
Shocking! Shocking i say...
I cannot believe one would even suggest putting anything on before lift and tires...pure rubbish.
trail cool = un cool
Its all about the BLING
Old 03-15-2007, 05:54 AM
tc
tc's Avatar
I guess I'm just the uncoolest guy around then ...
Old 03-15-2007, 07:26 AM
It is basically still stock except for some exhaust/F.F.cat./filter/lockright/31" BFG upgrades
I think I've lost my rake to the leaves...
Should stock Tacoma rear leafs arch down, up, or are they flat?
And will a lockright explode my front diff or birfs? I've got Toy manual hubs and I will be installing a 3/4" diff. drop when I regear and put the lift on.
Old 03-15-2007, 07:35 AM
I need to know these kind of things so I can keep it together.
I don't have time for a SAS or rebuilding something that blows apart.
Old 03-15-2007, 11:42 AM
tc
tc's Avatar
IFS doesn't have birfs, so I don't think you'll be exploding any.
In most situations, and IMHO the ones you don't have as much control over - a front locker will HELP your CV's. If you get a tire wedged in somewhere though, a locker will hurt them.
Search around for more opinions about front lockers. No need to rehash the ARB debate...
Flying91
45
04-11-2024 04:39 PM
makemusic116
08-02-2015 05:23 PM
makemusic116
08-02-2015 04:40 AM
Yotoder865
07-09-2015 07:51 PM
akaphilly
07-09-2015 02:18 PM
Quick Reply: 35's and 3" lift on a Tacoma?
