3" Drivetrain/Body Lift + New Crossmembers = ...
#45
Originally Posted by Lone4runner
thanks alot chris I appreciate all the pics you have posted. You definitely spent alot of time on this.
At any rate, I'd love to be able to put together a kit to do it, but I would need to borrow someone's 4runner for a long time to put one together. My truck has been modified to the point that I couldn't copy it effectively at all. The crossmembers are pretty simple to make, it's just the gas tank relocation that's a challenge, really.
Chris
P.S. I'm curious to see how SeaFlea's mustang tank comes out, because I think that's a better option so far, at least on the surface.
#47
Chris, nice work looks good. I was reading on Frontrange's site and they said that "The Crossmember fits all 4 cylinder gear driven cases. It does not fit V6 or Automatic transfer cases" is that true about the 3rd gens?
#48
Chris
#49
Chris I have a v6 auto and 2" bl and plan on running that setup. Do you have all the hardware in this photo, if you do I'll send you cash on thursday night.
#50
That's not the setup you want. I'm just talking about the crossmember for $200 shipped. You want the skid plate that goes from the left to right frame rail, not the one pictured, trust me. It would be separate. I've got everything you need to install the crossmember and for your setup it will fit perfectly.
Chris
Here's the pic of the one I have and it's much more durable and strong:
Chris
#51
Here's the latest specs on mine since the drivetrain lift and new suspension setup:
1) Width outside of tread to outside of tread: 68"
2) Wheels: Stock 1997 4runner
3) Suspension setup:
- Front - Tundra Coils, top out spacer, OME shocks
- Rear - LC 8 wrap coils, OME shocks, panhard drop, no rubber isolater cone
4) Height from ground to transfer case skid plate: 19 1/8"
5) Lowest point on rear bumper (Hitch tube): 27 3/4"
6) Bottom of sliders: 24 1/2"
7) Bottom of rear frame rails: 25"
#53
i am looking for the other....... thanks though
It's retarded to attach a skid plate to the transfer case directly. What good does that do? Nothing! All force is transfered right to the case. Dumb, in my opinion, but you're more than welcome to get that one instead!
Chris
#54
Does this mod (3"BL and 3" drivetrain lift) work if you've already got a 3" suspension lift? This would probably kill pinion angles, is there anything I could do to help those out? What would I have to do to make sure everything works ok if I were to go for this mod?
#55
You can combine lifts, no problem. Depending on the type of driveshaft you have, there may or may not be driveshaft/pinion angle issues. A single-cardan (all u-joints) shaft will be fine if you raise the engine and t-case the same amount. Everything stays parallel and there should be no problems:
- http://www.4crawler.com/4x4/CheapTri...FixingProblems
If you have a double-cardan (CV type rear shaft), then it would be required to tip the pinion up for any type of lift, suspension or drivetrain, about 1 degree per inch of lift. Adjustable control arms would do that on a coil sprung rear end, shims work on a leaf sprung rear end.
#56
If you have a 3rd gen you'll be fine. I've got about 4" in the 3" in the front and this mod with no problems with vibration. It's the best mod I've done, for sure. You'll be amazed at how well it helps you on the trails.
Chris
Chris
#58
Originally Posted by Albuquerque Jim
Chris, did you need to go up 3" with the drive train to get it flat?
Chris
#60
I am looking into clocking my dual case (when I get it) so I don't have to go up so high on the BL & Drivetrain. I like your results.
Chris
09-04-2015 09:27 AM
mistershmi
08-31-2015 03:44 PM
Pedalpwr27
08-13-2015 06:37 AM
coffey50
07-28-2015 10:55 AM
