2ng gen pickup IFS questions.
Originally Posted by Dr.Feelgood
Roger, according to the last paragraph in the ADD writeup, is it saying that the VSVs, etc can all be removed and NOT the ADD hubs, but yet still retain 4wd and shift-on-the fly? Or does it mean after you've replaced the hubs with manuals? I'm a little unclear on that.
I get it now. Sounds like it would be better to gut it and make the swap to manual Aisins rather than having all of that turning all the time. My ADD is working fine so I think it will hold up until then. I like the idea of having the 2lo as well.
That sounds better yet Roger. How would that be done? Can the swap be made without touching the ADD system, or does that include the mod to the actuator fork in the writeup? Does the actuator assembly eventually get removed as part of the gutting of the ADD or is that essentially what the mod allows for? Or, is it left intact altogether?
#25
There are a bunch of writeups on defeating or deleting ADD, read them and decide what you want to do. I've never had a truck w/ ADD nor ever worked on one, so I only know what is written in the on-line pages, one posted above and another below:
http://www.off-road.com/toyota/tech/add/index.htm
So you can either leave the ADD stuff all intact and functional. You can configure the vacuum lines to leave it engaged all the time. You can lock the internal mechanism to leave it engaged all the time, or you can swap the ADD actuator part for the non-ADD version of that part.
#26
I don't think I'm going to be in a big hurry to do it. I was looking at the conversion kit on Downey's site and it's $700 for the kit including hubs.
#28
I was looking at the diagram in the manual and it shows both hubs side by side. It appears from the illustration that the only differences are the manual locking knob, a 6pt gasket behind the knob (between the cover and housing). The ADD hub didn't show the gasket, but did have a donut-shaped thing behind the housing. It was hard to make out from the b&w drawing and also due to the size. There's a set of Aisins on ebay now for $50...
#29
Dr. Feelgood-the downey kit is for 3rd gens and tacomas...just unbolt our flanges and bolt on the aisins, simple as that it took me 30 mins.
Remi-here's the pics sorry for the delay, as far as lift they usually end up at around 3" but theres variables as they are a used spring that can sag, fortunately mine are pretty new ('98) and the way I've got em is right about 2". these are a couple old pics of the hangers, i've got the skids completed now. Plus chevies ride nice and soft like a luxury car (k maybe not quite but you know nice for a truck)
tpd143
07-07-2015 09:06 AM
Steezy96yota
07-06-2015 10:00 AM
FS[SouthEast]: 1st Gen 4Runner Slider Window, Driver Side
coryc85
07-06-2015 04:07 AM
