99+ Tundra, 00+ Sequoia, 98+ Land Cruiser/LX470 Late model full size trucks and SUVs
Old 04-15-2016, 09:39 AM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Toyota Tundra Steering & Suspension Guides
Print Wikipost
Tundra's camber adjustable?.. or buy camber kit???
Old 11-27-2004, 09:42 PM
slyang1012's Avatar
put in new tires... me likeeeeey... but the drivers fronttire is slightly at an angle.. like this.. passenger / drivers side respectively: | /
are the Tundra's camber adjustable?.. or should i buy a camber kit ??
tires are neww.. and i dont want to ruin my tires because of this. i just had my EX-tires rotated about a month ago after i got spacers. ANYBODY!! thanks
Old 11-27-2004, 10:02 PM
jimbo74's Avatar
there should be a little bit of adjustment on them, but if the wear is visible that bad, i would try to find out whats wrong with it.... it shouldnt need a camber correction kit unless suspension modification was done or something is damaged
Old 11-27-2004, 10:07 PM
slyang1012's Avatar
Hey jima... i had goodyear do an alignment before i changed my tires.. could i go back there and have them check it again with my new bigger and taller tires??? how bad can the tires get if i keep driving with it like that?.. its at about roughly 10-20 degrees by eye.
Old 11-28-2004, 04:14 PM
superjoe83's Avatar
yes, the camber is adjustable on the tundra's, the bottom two lower control arm bolts do the adjusting, and i would take it back, they may have left those bolts loose which allowed the camber to change while you drove it, or the person doing it didn't hook the machine up right
XtraCab
04-12-2020 05:25 AM
jerusry
10-19-2015 05:28 PM
Jonny246
07-12-2015 04:51 AM
crashburnoveride
07-10-2015 06:39 AM
Suprarossa
07-06-2015 05:21 AM
Quick Reply: Tundra's camber adjustable?.. or buy camber kit???
