Tundra's camber adjustable?.. or buy camber kit???
put in new tires... me likeeeeey... but the drivers fronttire is slightly at an angle.. like this.. passenger / drivers side respectively: | /
are the Tundra's camber adjustable?.. or should i buy a camber kit ?? tires are neww.. and i dont want to ruin my tires because of this. i just had my EX-tires rotated about a month ago after i got spacers. ANYBODY!! thanks |
there should be a little bit of adjustment on them, but if the wear is visible that bad, i would try to find out whats wrong with it.... it shouldnt need a camber correction kit unless suspension modification was done or something is damaged
yes, the camber is adjustable on the tundra's, the bottom two lower control arm bolts do the adjusting, and i would take it back, they may have left those bolts loose which allowed the camber to change while you drove it, or the person doing it didn't hook the machine up right
