Tundra Rear axles
Tundra Rear axles
I'm new to YT and yota trucks and i was wondering if the 03 Tundra had the same 8" rear axle as the Taco because I'm looking at putting in a LSD or locker.
I have another question where do i find the axle code so i can finally know what gears i have and if an Eaton or Dretroit is made for my rear end.
are you talking about the manufacturing date tag...beacause there are some letters and numbers i cant make heads or tails out of.
Dimensionally, it is all 8" of ring gear.
Interchange wise, Tundras, open diff Taco's and Sequoias have a diff with bigger pinion bearings, girdles and guts. It takes an RD89 from ARB, but just noting it is a Tundra should give correct application.
Some call it 8.8" while others say 8.4" At the shop we call it the fatty 8.
I understand that the Tundra has and 8" ring. What started this whole thing is its really difficult to find anything for Tundras, and what i was thinking about was buying a carier and possibly axle shafts for a taco and using it in my Tundra axle. But Fly wouldnt the sequoia and tundra have the same axles since they'er off the same platform?
All of them are 30 spline at the carrier.
Swapping the carrier will gain nothing, you cannot put an e-locked 3rd in anyway.
The shafts are different lengths between the rigs mentioned.
You can get an ARB or Lock-Right, that is pretty much it.
ok, so i can put any 8" taco carrier into my third member just not the E-locker or different shafts for a taco into the axle housing.
Now with that straitened out i might be able to do something with my truck.
argggg, thats crappy. But i thought that all open and LSD carriers where 8 1/4" but the e-lockers where 8" and if so why wouldnt i be able to swap carriers or third members.
06-01-2021 01:51 PM
jerusry
10-19-2015 05:28 PM
FS[GreatLakes]: Toyota collection part out
88sasturbotoy
08-11-2015 01:56 AM
