Tundra 2.5" Lift & Light Bar TECH
Originally Posted by slyang1012
hey, how does ur truck run with the spacer? can u tell the diff besides it being leveled? got anymore pics?
Looks good, but what about your CV boots? Did you replace those?
Your right about the nose down look of newer vehicles, I parked my Tundra next to a 2nd Gen runner the other day, and the 4Runner had more ground clearance than my tundra, very sad, very very sad indeed .
You won't need to if they are strong enough to hold, but the earlier versions (2002 and below) had problems with weak clamps and the boots tearing as a result.
Spacers
Won't installing spacers cause the tow in-out / camber of the tires cause excessive tire wear? I just want to know just how safe it is because I want to do the same and finding intel on such a lift is so vast that I would rather just ask one of you. Does anyone know the cheapest and easiest way to lift a Tundra?
Daystar's are your best bet for a short lift, and you're right about the alignment issue, that's why your supposed to go get an alignment after installing the lift,
And the Daystars are safe? What all is involved? I just want the look. Should I choose a body lift instead? Thanks for the input.
Safe? All lift are generally safe, it's driving habit that makes aftermarket mods unsafe. The reason why I suggested Daystar is it seems to be the only one out there that is gives as close to original ride quality (slighty stiffer).
It's simply a matter of adding a spacer to the coil (if you're going for a short lift) and either add-a-leaf in the rear or blocks.
Oh forgot about this too, seems like a good product: Extreme Toys EZ-Lift
Originally Posted by dweidman
Nice of you to spend the time to reply. What about the body lift? I just want the looks? Would this be a better way to go?
Originally Posted by WildYoats
No, I did nothing with the CV Boots. I was told I did not need to. Hopefully that's correct.
Flying91
45
04-11-2024 04:39 PM
06-01-2021 01:51 PM
09-04-2015 09:27 AM
DrZero
18
07-24-2015 11:31 PM
Suprarossa
07-06-2015 05:21 AM
