Questions about my 1998 LC and making it more off-road capable.
Well let me tell you from experience driving other SFA vehicles. A coil and linked SFA is smoothest setup compared to leaf springs.
Likely it sounds like you could use FZJ80 front axle on your 98 cruiser. However then your stuck with a 6 lug front and a 5 lug rear unless you changed both axles out.
Anyways good luck in whatever you decide.
Here's the full article on the FJ100 swap if you decide to do it. http://www.4wdandsportutility.com/te...ade/index.html
I have a 98 Toyota Land cruiser. I was considering doing an SAS swap. But I want to keep the driving comfort the same as it is now. I want to fit 35"-37"(havent decided yet) on my landcruiser. I have these two options that I wanted, but I'm not sure which one to go with.
option 1: SAS swap. It will affect my cornering ability and driving comfort, but it will have more off road capability. Less maintenance.
option 2: Keep the IFS and get an Old man emu 2" lift with a 1" slee off road front diff drop. Trim the fenders by 1" to be able to fit bigger tires. This option will help keep my LC's driving comfort about the same as it is now. I still think it would be pretty capable as an off road rig, because I've seen people go on some trails with an IFS suspension.
I use my LC daily. I don't need flex to climb over rocks. I mostly do my 4wheeling in mud. I take my LC to oceano dunes every now and then.
Knowing this, which option would be better for me?
#26
dang, your helpin me on all my posts. But same question, do you run the 4crawler.com site?haha
#29
Does anybody know if the OME 863 springs only provide 3" lift with the stock bumper? called slee off road and they told me that if I use the stock bumper, the truck will get raised 4" in the rear. Also, they told me the 866 springs will raise my truck 3" with the stock bumper in place. I was planning to get a tube bumper with a spare tire carrier in the future, but for now all I want to do is raise my 100 series. Can I run the ome 863 springs right now and get only 3" of lift? Can I level out the truck with the torsion bars if it's raised 3" in the rear? Someone help me please. I want to order my parts ASAP
the1998sr5
15
07-14-2020 08:35 PM
TURBOrunnerNM
07-22-2015 11:01 AM
icentropy
07-14-2015 10:23 AM
