265/70/17 tires
265/70/17 tires
Has anybody put on 265/70/17 tires on a stock Sequoia? From the factory they come with the 265/65/17.
Matt
Matt
Originally Posted by celica
Has anybody put on 264/70/17 tires on a stock Sequoia? From the factory they come with the 265/65/17.
Matt
Matt
Go to www.tirerack.com and check out their site, it sell let you know if the tire will fit your rim or not.
I know it will fit the rim as it has the same with, it is the overall diamater and the room in the fender I'm worried about. There isn't a lot of room when the fron wheels are turned slightly between the reaer of the tire and the rear of the fender (on the front). I was looking to see if anybody has done it and how much (if any) rubbing they are having. The 265/70/17 size seems to be available in more tires then the stock size.
Matt
Matt
Ok, depending on the tire manufacturer, a 265/65/R17 has a diameter of 30.6" and a width of 10.4". A 265/70/R17 has a diameter of 31.6" and the same width of 10.4"...these measures are of a BFGoodrich tire. So you may have to do more research on the fit but I can tell you that I currently fit the 265/65/R17 on a stock 1995 T100 4x4 with a stock suspension and I have plenty of room. and I must say the tundra/sequoia 5 spoke rims look good on a T100...
They fit - also check your owners manual
My buddy has 05 Tundara with the 17" Sequoia (style) wheels, and he just put 265 70 17's BFG AT's on. I'm going to do the same with my 03 Limited Sequoia. You may get a little rub when the wheel is turned to lock on U turns etc.. BTW - Read your book that came with the Sequoia It states either tire can be used ( 265 65 17 or optional 265 70 17) . They really look great I must say. The wheel well gets the treatment it deserves.
Cheers
Cheers
im getting a new tacoma and want to put a set of new 265/70/17 dualer at's that are from my dads tahoes stock rims he never used, are they going to fit, you guys ever get this resolved
1uzRunner
63
11-10-2018 03:58 PM
Williamemslie
14
10-05-2015 09:28 AM
FS[PacNorWest]: 1993 4 Runner, V6, 4wd, Auto,
AkitaDog
09-03-2015 09:01 PM
