The Ruffstuff Heim Joint Revolution Continues!
FormerVendor
I am reposting this from another website so you do not think these are a brand new item or process for us. We have been making and selling what we believe to be the Strongest & longest lasting Heim Joints for quite some time now.
When I first posted this up a year and a half ago we were well past the testing phase and getting stock levels high. Today (8/7/11) we have over 8,000 in stock in all sizes with all the Bungs, Jam Nuts, & High Misalignment to go with them.
This was a huge undertaking for a company our size but assuring the supply and going direct to the factories was the only way to make the price fair. Rod End prices have always been stupidly high and we have eliminated the middle man to bring them down to earth!
UPDATE, 5/29/10
Big changes here at Ruffstuff on our Heim Joints! We have been doing some research and testing for the last 10 months and have come up with something very interesting! What we have discovered should have been very well known but seems to have been overlooked by the industry.
Everyone knows the benefit of Heat Treating and of course all of our heims are HT, its only common sense. Most of you know about Cryogenic Treating of metals after HT also, something that shouldn't be overlooked as we subject things to greater and greater stresses.
What has been overlooked are the benefits of Cryogenic Treating to other materials. I am talking about Plastics, Nylons, & Teflons, the very materials our Heim Joint bearing liners are made from. The realignment at the molecular level of the material smoothes the surface and improves density allowing for a much longer bearing life. 10 Months is not 5 years and we don't have a machine to put something through 20 million cycles but we have recorded less than 1/2 the wear in the test group in favor of the Cryo treated. That would indicate 50-100% longer lifespan of the joints that have been cryogenically treated.
With our limited testing ability I am going to have to side with the scientists opinion. I won't cite research sources, you all have Google too so you can do the same search and see for yourself!
The benefits are many and we simply haven't found anything detrimental from the process. The Cryogenic process also makes the HT Rod End AND Ball harder from further martensite conversion (Talk to the scientists). This process increases the ultimate radial static load 8-15% but we will not make any claims of further strength we cannot afford to prove but you can safely assume a 78,000lb RSL heim gains 3-5,000lbs in RSL.
This is the first product we have sold that hasn't been made by us, now they are made to our specs by one of the best manufactureres in the world. And by the end of next week all of our Heim Joints will be both Heat Treated & Cryogenically Treated!
UPDATE, 5/29/10
FormerVendor
The best option is also one of the least expensive options. We cut out the middlemen and go direct to the factory eliminating a layer of cost to you!
kawazx636
10-06-2021 03:03 PM
FS[MidWest]: 1.5" ball joint spacers
4x4YOTA
08-23-2016 09:08 AM
FS[SouthCent]: TX - 4Crawler Ball Joint spacers
crash813
09-27-2015 07:15 AM
Odin
09-26-2015 06:56 PM
bungs, ca, heim, heims, joint, joints, jointssacramento, made, revolution, ruff, ruffstuff, sacramento, strongest, stuff, usa
