IDEAL 63" Chevy Spring Swap!
Old 09-09-2014, 01:09 PM
FormerVendor
Gravel Maker's Avatar
Finally the full kit! Everything you need to fully put those wonderfully versatile 63" Chevy Springs under your rig. We have offered a couple of options so you can fully customize the way the springs are set up on your vehicle. We suggest using the 5" shackles because that will set you up with the 65-70 degrees of angle to prevent your springs from inverting yet allow full flex, but sometimes people want a shorter or longer application depending on what axle they are running. We also have the option what size axle tube you have, because we all know how many variables there are!
This is the everything kit, if you need something less check out the other option...
They can be both found here...
Leaf Spring Swap Kits - RuffStuff Specialties
Old 09-22-2014, 08:32 AM
FormerVendor
Hope everyone had a fun weekend!
Old 10-15-2014, 07:29 AM
FormerVendor
Don't hesitate to call us with questions, we love to help!
Old 11-17-2014, 09:41 AM
FormerVendor
We had a pretty busy weekend! All thanks to you!
Old 01-20-2015, 09:00 AM
FormerVendor
This is just one thing you can't go without!
Old 02-12-2015, 09:41 AM
FormerVendor
Thursday already?! How this week has gone by so fast!
Old 02-23-2015, 11:34 AM
FormerVendor
The product you want at the price you can afford!
Old 05-06-2015, 09:15 AM
FormerVendor
Our shipping is simple, fast, & convenient!
Old 07-08-2015, 03:02 PM
FormerVendor
Be sure to add this to your wish list!
Old 03-11-2016, 07:29 AM
FormerVendor
As it says, the IDEAL kit for mounting 63s into any generation of Toyota.
Old 03-24-2016, 09:29 AM
FormerVendor
Make the job that much easier, we all know you can start with cardboard templates, and use up 10 cutoff discs.
But why? When we have laser cutters?
Old 04-12-2016, 05:22 PM
FormerVendor
Pretty amazing how much steel you can fit in a flat rate box sometimes...
Old 09-13-2016, 03:07 PM
FormerVendor
Blow the dust off your tools and get to work!
Old 11-10-2016, 12:57 PM
FormerVendor
The best way to get it done!
Flying91
45
04-11-2024 04:39 PM
rondogracing
Engine Swaps
16
08-24-2015 03:02 AM
boogiewoogie
07-24-2015 05:10 AM
wilbertd
07-06-2015 07:39 AM
Quick Reply: IDEAL 63" Chevy Spring Swap!
