IDEAL 63" Chevy Spring Swap!
FormerVendor
Finally the full kit! Everything you need to fully put those wonderfully versatile 63" Chevy Springs under your rig. We have offered a couple of options so you can fully customize the way the springs are set up on your vehicle. We suggest using the 5" shackles because that will set you up with the 65-70 degrees of angle to prevent your springs from inverting yet allow full flex, but sometimes people want a shorter or longer application depending on what axle they are running. We also have the option what size axle tube you have, because we all know how many variables there are!
This is the everything kit, if you need something less check out the other option...
They can be both found here...
Leaf Spring Swap Kits - RuffStuff Specialties
FormerVendor
Make the job that much easier, we all know you can start with cardboard templates, and use up 10 cutoff discs.
But why? When we have laser cutters?
Flying91
45
04-11-2024 04:39 PM
