Tube Shock Towers!
Old Feb 16, 2015 | 09:20 AM
Gravel Maker's Avatar
FormerVendor
Tube Shock Towers!
Here is a pair of 1.5"x.120 wall DOM shock hoops. These are not the typical both sides even type everyone else makes because often your mounting surface and where you need to mount them simply have to be different. These make it easy to mount them tilted forward or rearward and have enough tube. If you are one of the lucky few that can mount them straight up and down just cut off the extra tube!
They come with two pair of our curved shock tabs so you can fine tune the height adjustment by the position of the tabs.
Shock Hoop 1.5" - RuffStuff Specialties
Old Mar 22, 2016 | 09:22 AM
FormerVendor
Beefy and simple, not need to over complicate when it comes to mounting your shocks, coil-overs, or air-shocks.
Old Apr 4, 2016 | 09:36 AM
FormerVendor
Sized to be able to fit almost any application!
Old May 4, 2016 | 08:38 AM
FormerVendor
Lightweight, but really f***ing strong!
Old Oct 10, 2016 | 08:01 AM
FormerVendor
Easy to work with and get attached to the frame, however it works for you.
Old Nov 14, 2016 | 01:03 PM
FormerVendor
These guys are ready to handle as big of jumps as you are willing to.
toyotasaurus
Sep 24, 2015 03:30 PM
adamk
Sep 24, 2015 03:59 AM
sonorn67
Sep 19, 2015 05:39 PM
Dparr2ndgen
Sep 8, 2015 01:06 PM
