New 80 2wd!
Oh also today I got stuck and I thought the right tire spins and the left one doesn't? Cause When I got stuck the left spun and not that right one
#26
Sponsor
yep.. one tire fire! that what happens when you have an open diff.
to clarify my previous post. if you buy a lockright for a 86-95 4runner/pickup FRONT diff (7.5" diff) it will fit in the rear of a 2wd pickup.
#27
How hard is it to put in? Also in thought one tire fire was the right tire not left
#28
its what ever tire has the least amount of traction....one way I have found to fight that in the mud or snow (with out a locker) you just lock the ebrake and it will put the same amount of drag on both back tires and make them both pull...
#29
Hate to revive a dead thread, but did you have to do any body lift or torsion twist to clear the 30" tires? I am resurrecting an '82 and I want to stuff as much tire as I can under there without lifting or rubbing.
Dale Johnston
11
10-31-2015 10:22 PM
Cycles
09-29-2015 06:37 AM
