would this help bring my back end up?
Old 07-23-2008, 08:06 PM
yotalover96's Avatar
MR GASKET RUBBER COIL SPRING SPACER, FRONT -- 1'' Lift, 4'' Inside Diameter, 6'' Outside Diameter, An Ideal Way To Raise All Coil Spring Equipped Cars Without Affecting Handling Or Ride, Features U Shaped Section, Fits Above Or Below Coil, Requires Spring Removal To Install, With Manufacturer's Limited 90-Day Warranty"
or where can i buy new replacement springs
thanks for youe help
Old 07-23-2008, 08:08 PM
o ya and if this will help i can aford them
Pro Comp Rear Leaf Spring
1984-1998 Toyota 4Runner"PRO COMP ADD-A-LEAF KIT, REAR, SHORT -- 1.5" - 2.5" Lift, Helps Renew The Height And Strength Of A Rear Spring Suffering From Fatigue, Strengthens The Integrity Of An Existing Leaf Spring Pack, Includes Two Single Leafs And New Centering Bolts, With Pro Comp's Limited Lifetime Warranty
Old 07-23-2008, 08:22 PM
'884Runner's Avatar
What kind of vehicle do you have? That would be really important seeing as you are looking at parts first for something with a coil spring rear suspension and then something with leaf spring rear suspension. I have never heard of the Mr. Gasket stuff, and if your vehicle has rear leaf spring suspension, then you should be ok with the AALS
Old 07-23-2008, 08:24 PM
crolison's Avatar
You are posting in the 3rd gen 4runner section, which they have coil springs in the rear. I would suggest getting some ome or some 99 springs for the rear.
Old 07-23-2008, 09:06 PM
X-Tool Pimp's Avatar
MOD EDIT: (Lysmachia) BANNED!
Old 07-23-2008, 09:07 PM
Mason Dixon's Avatar
i guess the mods are asleep?
Old 07-23-2008, 09:43 PM
Lysmachia's Avatar
X-TOOL posted 60 bannable images. Way tooo much crap.... I coulda banned all posts but I wanted everyone to see what a jerk he was. 60 posts of the same Image... I hand cleaned this one.
Come on Guys! We ALL OWN YOTA's Who cares? Let's leave the fighting to the hummer guys!
Old 07-24-2008, 11:21 AM
ya i have a 1996 2wd 4runner and there more i think about it i want to lift it and turn it into a prerunner so would a toytec 3" 4Runner Lift Kit
Included in kit:
3" Front Lift Spacers-- CNC Machined From T-6 6061 Aluminum
6 longer top plate spacer studs
3" Rear Lift coil springs (2" lift rear coils also available-same price)
Install Directions
help it rather then buy new springs or spacers
Old 07-24-2008, 11:34 AM
wjwerdna's Avatar
It will work... my lift was all spacer at first... just about 7-8 mo ago I finally replaced the rear with OME springs from someone on here, SO MUCH BETTER =)
Right now I have the springs, AND a 1" rubber spacer from AutoZone in the rear... for 3.5ish" lift total. The kit you just listed doesnt sound too bad
Old 07-24-2008, 11:50 AM
gilby4runner's Avatar
Just go with OME. Spacers would work but it really depends on the shape of your current coils. If they are sagging then your just putting a band aid where you need stitches. Look into the 881 / 906 combo. I know there are a few threads about them on here. I recently installed it and i am very pleased.
Old 07-24-2008, 12:03 PM
will those coil over springs work my stock 2wd or do i need somthing else to make them fit?
Old 07-24-2008, 12:12 PM
crolison's Avatar
they will work, 2wd and 4wd runners have the same suspension set up, just different struts and springs.
Old 07-24-2008, 12:18 PM
will they make my yota sit higher from them being stronger?
Old 07-24-2008, 07:24 PM
giguchan's Avatar
My 97 usta sag in the rear like my ex girlfriend.I had the daystar spacers installed and now she sits all level... I forget the size i had installed but i think that were 1.5? anyhow you cant go wrong with them.. inless you have other issues..
Old 07-24-2008, 07:28 PM
07sbock's Avatar
Coast your 4runner to the local stealership, Tell them that you want the coil spring re-call special!
*The rear springs are under re-call and you get a brand new set of rear springs for FREE!!!!
After that da sag be gone!
Old 07-24-2008, 07:33 PM
giguchan's Avatar
I took mine to the dealership and had the recall done.. it did not fix the sag. the only thing that fixed MY sag was the spacers.. I thought the recall was supposed to fix the sage too. but i was wrong..
Old 07-24-2008, 07:56 PM
so the daystars will give me lift aswell as fitmer rid
Old 07-24-2008, 08:27 PM
giguchan's Avatar
Hey,
I guess you can say that i got a "lift" out of the install. I did noticed a firmer ride since i had them installed. I tow things Pop up trailer, jetski ,small bassboat Without the spacers it would sag and with the load it would even more.. I think it looks better, and i think it performs better with the spacers. I was not looking for a lift persay-But more for leveling purposes..
Charecter1
11-06-2023 10:08 AM
icentropy
09-16-2020 02:47 PM
toyoda8488
07-05-2015 10:18 PM
elwood73
07-05-2015 07:07 AM
Quick Reply: would this help bring my back end up?
