Wiring trailer lights???
Old 04-04-2010, 04:44 AM
SourMash's Avatar
My 2000 4Runner did not come with the towing package. However, I installed a hitch, now I need to hook up some wires. Can someone tell me where to find the wiring harness? Thanks,
Andy
Old 04-04-2010, 06:00 AM
Toyota95's Avatar
You should be able to find the wiring harness a trailer store, auto parts store, toyota dealership, camping world.
Old 04-04-2010, 11:32 AM
Elton's Avatar
something like so
http://www.suspensionconnection.com/...scon/7277.html
Old 04-04-2010, 12:53 PM
SourMash's Avatar
Thanks for that link! Now can you tell me, where on my vehicle is the wiring harness located ( that I'm supposed to plug into)??
Old 04-04-2010, 06:11 PM
portercassidy's Avatar
You should get some instructions with your purchase, but essentially you will be connecting to the wires behind your tail lights. You will have to move the sides of the back of the cargo area to access the tail lights. There is also a plastic piece you will have to cut underneath the weather stripping.
Pretty straight forward
Old 04-05-2010, 05:32 PM
SourMash's Avatar
Thank you very much.
Old 04-14-2010, 04:09 PM
FORANA's Avatar
Hey guys. I installed my trailer wiring and for the life of me I can't figure out how to run the wire to the outside of the car. I've just been running it out the back and shutting the backdoor over it. Can someone show me where to run the wire from inside to outside?
Old 04-15-2010, 04:04 PM
FORANA's Avatar
aneee one?
Old 04-15-2010, 06:15 PM
SourMash's Avatar
I'd help ya, but I don't know either. I did order one of the harness's that is listed above but it has come yet.
Old 04-17-2010, 11:33 PM
wyoming9's Avatar
Red face
I just drilled a hole in the floor put a gromet in and sealed it up with blue silicone .
I also made up my own harness using plugs for the left tail light harness then just running a wire from the right turn signal to the plug harness.
I also used the 7 wire trailer cable as I needed the extra wires for the electric brakes
Old 04-18-2010, 07:12 PM
ZGjethro's Avatar
Like ^^^. I used a six wire plug since it had a sealing flip lid and is better than having a four wire plug dangling beneath your bumper. Six to four wire adapters are easy to find.
Old 08-17-2010, 06:49 PM
fishingstud's Avatar
ok, not a 4runner but a t100, where is wiring harness located? feel free to write me.
smthwsn357
12-04-2023 02:08 AM
Sleaker
08-26-2020 06:03 AM
BeMiceElf
10-10-2015 09:40 PM
Johntom240
7
07-13-2015 12:18 AM
toyota32
07-06-2015 05:42 PM
Quick Reply: Wiring trailer lights???
