Winch Not Working (need help)
Old 12-27-2003, 03:45 PM
Hyperlite's Avatar
Question Winch Not Working (need help)
My Mile Marker 8K electric winch was working when I put my truck in the garage 2 months ago. I rebuilt it and got it to free spool and it worked when I put it back in. Now both selenoids will click (fwd/rev) but no action in the winch. The battery was low (11v) the last time I tried to work it. Could this low voltage cause my winch to mess up? What the hell is wrong. It is not water/mud damage, in less from a long time ago..........
:pat:
Old 12-27-2003, 04:31 PM
92 Toyota's Avatar
If your battery has enough juice to start your truck it will have enough to turn your winch.Although it may not be able pull a load.Try cleaning all your connections & see if that helps.Also if you don't off-road alot you should run your winch everytime you change your oil,wind out some cable then wind it back in.(That's what my owners manuel says)
Old 12-27-2003, 08:43 PM
Hyperlite's Avatar
This winch has seen more action than a winch from Bangcock....
I have an 6 onth old Red Top Optima. I run high current stuff (winch,altinator, stereo) off of main terminals and my 10 Hellas off of the side terminals. I have added another wire from the altinator and it runs at a steady 13.5 volts. It seems that it is not getting power from the selenoid. The winch worked perfect before (quit free spooling for a while) and has been rebuilt once. Could an arch or low volts cause serious damage to a winch and not the selenoid. It is connected the same way it has always been. How would you test the winch/selenoid with a volt meter? When I mounted it I extended the cables with 4 gauge wire 4 feet from the winch to the selenoid to move it under the hood (been like this from day 1)--could that F it up?
Old 12-27-2003, 11:52 PM
Guest
Breezey's Avatar
wow.. My Winch sometimes does the same thing as your talking about. I think it may be a de-fect.... I am going to call Mile Marker monday morning. Mine does still work and I am useing the e9000....
ashersullivan88yota
01-18-2022 05:37 PM
06-01-2021 01:51 PM
Huntingtruckcletus
07-08-2015 05:26 PM
toyoda8488
07-05-2015 10:18 PM
Vargntucson
07-04-2015 12:15 PM
Quick Reply: Winch Not Working (need help)
