Will this TRD Supercharger work?
Off a "car" with 120,000 miles.
The guy claims it worked just fine.
Wants $400.00.
How much work would be involved with this "bolt on", for my 1997 4Runner Ltd. with Auto tranny?
Off a car? Looks like a 1st gen trd sc for the 5vz. Well you need all the brackets and hoses. Then you need to worry about the fuel delivery and leaning out.
I picked up a second gen sc for 400 and then another 400 for the brakets and hoses and bolts. Then another 600 for fueling.
Looks just like mine
Should work fine, i got mine for $300, then $300 for a rebuild and have been running it for 2 years now with no problems.
I did find out that my bypass valve was leaking though so something worth checking, if it is i am working on getting a replacement valve made to fix the problem.
For fueling, you can go with a URD 7th kit like most or do what i highly recomend and get a nice Meth injection system and use that for the extra fueling, i removed my 7th injector 5 months ago and have been running on nothing but meth injection. Will never go back to the 7th.
It has so much more power, easier to tune, more consistent, safer, i am 100% happy with this setup. It is cheaper too.
Here is a thread with some reading on the subject: https://www.yotatech.com/forums/f2/t...-power-222044/
Also got a few more older threads on installing the 1st gen SC like that including the TRD instruction manual if you search my user name.
Here are some videos on the subject I made as well:
http://www.youtube.com/watch?v=lLnFf0_H8bI
http://www.youtube.com/watch?v=SYBOlsLTZQ8
There are more on my Youtube Channel as well.
Def needs a rebuild. Minimum $300 - up to $750 if it needs rotors replaced.
Also, it needs a dynamic tensioner kit ($250 or so) gaskets, IAC check valve, a few random bolts.
I wouldn't pay more than 250 for it, unless he has the tensioner kit and missing bolts...
Then you will want fuel mods so you don't ping....
ashersullivan88yota
01-18-2022 05:37 PM
06-01-2021 01:51 PM
