| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Will it rust????
#2 (permalink) |
it should be ok, because the water will be able to drain out of the front of the bed, unless it has a lot of buildup of mud and crap, id take out the liner, hose out the bed, and seal up the holes in the liner with silicone
__________________
- Joe 1984 SR5 4runner, 22re, 5-speed, chevy 63"s, rears up front custom pack, BBCS shocks, 2" BL, 5.29's, welded rear, Detroit in front, Longfields, IFS Rear, 39.5x13.50x15 IROK's, Marlin's High Steer, MC07 with stock cases, Marlin's cross member, tube bumper, Warn XD9000, Allied Beadlocks 1999 Taco 2.7 5-speed, LCE Header, Jardine 2.25 Cat-Back, 3" Downey Coilover, 33x13.5 Toyo MT's, ARB Bull Bar, Retrofitted Acura TL HID Projectors with 50W ballasts and 50W DL50 Philips 3900k bulbs |
#3 (permalink) |
Good advice, thanks superjoe.
#4 (permalink) |
OR better yet... take out the liner, wash out the gunk, and then get a good quality spray-on liner like Rhino-lining or Line-X
#5 (permalink) |
Yes, eventually it will rust. How long is the real question. A lot of factors contribute to the severity of rust with a drop in liner...
Where you live How tight it fits How often the underside is cleaned (of the liner, and the truck bed) So, I agree with Peter. Completely sealing it off is the way to go. I used to work for Rhino, so I am a bit partial as to which liner to go with.
__________________
www.rimpainter.com Get your O Gasket Mod Here! My SC'd 4Runner's Profile My YouTube vids |
#6 (permalink) | |
Quote:
I had a bedliner in my 94 Ranger. It was slippery and useless. I took mine out every month and you would be suprised on how much crap is under there. I ended up getting Rhino Lining and it was 100% better!
__________________
-Travis 1997 4Runner SR5 V6 4X4 Supercharged Desert Dune SOLD :( 1992 Celica All Trac (AWD-Turbo) #223 of 271 US spec for 1992 FOR SALE 2005 Tundra Double Cab Limited 4X4 2.5" lift 265/70R17 Dueler Revo's 4Runner and Celica Webpage |
#7 (permalink) |
Super Moderator-Sponsoring Member
Staff
A bolt/screw in liner is of the
and will eventually rust out your bed. Get rid of it and get a spray in liner that leaves no air between your precious metal and the liner. With the first type of liner it is not if it will rust, but when. With the spray in liner you won't have this problem.
__________________
WabFab Off-Road, LLC MySpace 7th Annual South East 4Runner Jamboree, 2010 The toughest part of a Jeep is the chick driving it. WabFab Off-Road 4th Anniversary Sale |
#8 (permalink) |
I had a 95 Tacoma that came from upstate NY. The bottom of the truck was quite rusty from road salt. It had a OEM Toyta liner in it with four holes where the tie downs were. There was zero rust under the liner after being in there for five years. I took it out twice a year to wash and clean junk from under it. There was never any wetness under the liner when I removed it. It may have been the tight fit of that liner, but I never had a problem. My problem with drop in liners is stuff slides around really badly.
__________________
Chris Mine-94 SR5 4-Runner, 3.0, 4X4, Aisin Hubs, Yakima Load Warrior, 210k Miles | Wifes-99 Limited |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| to much rust? | 87toypu | Pre 84 Trucks | 7 | 04-05-2007 04:03 PM |
| More and more rust.... | 854runner | 95.5-2004 Tacomas & 96-2002 4Runners | 26 | 11-07-2005 04:12 PM |
| Rust | TacoLuv | Maintenance & Repair Archives | 6 | 09-27-2004 11:30 PM |
| Rust!!! | ohio | 95.5-2004 Tacomas & 96-2002 4Runners | 3 | 03-24-2003 09:06 AM |
| Rust!!!!!! | 1Runner | 95.5-2004 Tacomas & 96-2002 4Runners | 5 | 03-03-2003 05:18 AM |
