Will the ISR Mod work on my 03 Taco?
Old Nov 16, 2004 | 05:27 AM
TBob's Avatar
I looked at it but it looks like it's all one piece.
Thanks,
Bob
Old Nov 16, 2004 | 05:28 AM
rimpainter.com's Avatar
Yes, it should work. You have to section it or go with the Air Raid tube. Can you post a pic?
Old Nov 16, 2004 | 07:24 AM
TBob's Avatar
I can post one tonight. I already bought a 12" Stainless steel .065 tube
that measure 2.5ID and 2.625OD. I was realy hoping I wouldn't have to cut up the stock one. Maybe I could buy the ends like the 4runner has?
Old Nov 16, 2004 | 08:06 AM
blink's Avatar
Hey tbob, i would suggest using a different material other then metal, since is conducts heat all to well. I went with the airaid intake which is made of a heat resistant abs plastic. you might be even better off using your stock intake tube... just my 02 cents
Old Nov 16, 2004 | 08:22 AM
Schuey2002's Avatar
They don't make a AirRaid tube for the 2.7L, do they?
Old Nov 16, 2004 | 08:29 AM
blink's Avatar
nope, atm they dont, but im sure if the interest was high enough they would make one. maybe ill drop by and talk to them about it(since they are about 5 minutes away from me) if you want
Old Nov 16, 2004 | 10:11 AM
Schuey2002's Avatar
Yes! Talk with them..
Well, if it wouldn't be too much trouble.
Old Nov 16, 2004 | 10:12 AM
blink's Avatar
np anything for a fellow yotatech member
Old Nov 17, 2004 | 06:28 AM
TBob's Avatar
here is the pic - I've heard of other using exhaust pipe. I've never heard of a concern with heat?
Old Nov 17, 2004 | 06:34 AM
That is exactly like mine, except you do not have the rear silencer. All you need is a cleanout plug from Home Depot and a barbed fitting for the FPR line. You may also need to pick up some vacuum line from Checker because it may not reach after you do the mod. Piece of cake.
Old Nov 17, 2004 | 06:40 AM
TBob's Avatar
so you guys are cutting up the intake? I thought this was a reversable mod?
what is a cleanout plug? where does it go?
Old Nov 17, 2004 | 06:46 AM
Nope, no cutting needed. Just replace that big ugly box with a black cleanout plug and a barbed fitting.
Old Nov 17, 2004 | 06:50 AM
TBob's Avatar
Christian is what your calling the clean-out plug the tube that replaces the box? - do you think using SS pipe is a problem?
Old Nov 17, 2004 | 07:07 AM
blink's Avatar
hey
tbob...you are local.... lets meet up some time and ill show you my intake
Old Nov 17, 2004 | 07:12 AM
BOSTON4RUNNER's Avatar
i would go to a plumbing place, home depot etc
get some hose etc, get some exhaust tubing
mine is set up so that I can throw the stock stuff back in, in an hour
I took my air box out, but you should be able to make this mod by using some rubber tube sections, weld a couple ports into a steel intake pipe, made from exhaust tubing or whatever...
tim
Old Nov 17, 2004 | 07:13 AM
TBob's Avatar
I live in Mesa - Higley and southern area. I realy want to do the ISR mod and the throttle body and gasket mod. I've already done the deckplate with and Amsiol filter. Unfortunatly I just order $20 buck worth of SS tubing that it sounds like wouldn't be good to use.
Old Nov 17, 2004 | 07:18 AM
Stick with the stock tube on this one. TRUST ME.
Old Nov 17, 2004 | 07:19 AM
Sounds like we need a little wrench-a-thon.
Old Nov 17, 2004 | 07:21 AM
blink's Avatar
Hey bob,
private msg me a number i can catch you at and we'll meet up ALways fun meeting board members
Old Nov 17, 2004 | 08:22 AM
3.4v6's Avatar
TBob
you can just get a pair of PVC plugs and just plug up that boxy silencer and th "J" one. and if you have a nipple sticking out of you intake manifold towards the center of the truck then just get some hose and connect that to the nipple the boxy silencer is connected to.
