Where to hook up the amp...
Old 08-28-2003, 01:26 PM
Guest
4RUNR's Avatar
Here's the situation: small 100wx1 amp going under the passenger or driver seat. It will be used probably for a tiny sub to give the midrange a little 'oomph'.
I'm quite well versed in the whole deal and do agree that the ideal thing would be to run a cable from the battery, but the voice of reasonability tell me that even a 10amp feed would be enough since it would hardly be ever turned up. Plus no mess with holes or taking too much apart.
Here's the question: what would be a good place around the dash area to get a constant 12v? (amp will turn on from remote coming off the headunit)
Old 08-28-2003, 01:31 PM
Cebby's Avatar
I know its a PIA, but you should still go to the battery for even a small amp. Everything will suffer if you take a shortcut like that (possible damage to under dash wiring, amp will get starved for not enough current, etc.)
I had a 45x2 amp that I was running in trimode on my wifes old Tercel (years ago). I was able to push a set of Boston components up front and a 12" RF sub in an infinite baffle set up. I sounded remarkable good and got some good volume!! I had 8ga straight from the battery for it.
Old 09-01-2003, 01:24 PM
Guest
4RUNR's Avatar
'Overcompulsiveness' took over so ran an 8 gauge from the battery for a total cost of ~$5
Good thing that same point after the fuse can be used for lights and anything else. (PepBoys fuse)
Old 09-02-2003, 10:43 AM
customcruiser's Avatar
RUN CABLE FROM BATTERY!!
it may seam that it doesnt pull much power, but it will
Old 09-02-2003, 10:03 PM
secondone's Avatar
Go to a local stereo shop and buy a 100 or 200 watt Amp wiring kit. It should cost no more than $30. Run the wire directly from the battery. Everything you need will be included: 8 guage power and ground wire, a fuse holder, 30 amp fuse, a grommet for the power wire, O-rings for power and ground, heat shrink, zip ties and split loom to clean it up.
Don't take shortcuts, you will pay the price later. E mail me if you want a list of tools you need to do the job right. That way, you can add a bigger amp in the future easily.
-Nick
JonG85
01-18-2023 04:31 PM
Steven.m.paulk
06-07-2020 10:45 AM
RDubya
02-10-2017 04:46 PM
smilen724
13
11-08-2015 04:11 PM
beltcutter
09-30-2015 06:14 AM
Quick Reply: Where to hook up the amp...
