What are the side effects of a leaking water pump?
Old Jun 19, 2005 | 07:32 AM
Crux's Avatar
Bad gas mileage?
Rough idle?
Help inform a newbie
Old Jun 19, 2005 | 07:46 AM
4Crawler's Avatar
Originally Posted by Crux
Bad gas mileage?
Rough idle?
None of the above. If it is leaking from the weep hole underneath the pump, that means coolant is getting past the internal seal and into the bushings in the pump shaft. Coolant washes away the lube in the bushing, causing it to wear out and then the pump siezes. If the leak is very slow, it may take months for the above to happen, but one the leak gets obvious (puddle on the driveway), it it just about ready to let go from my experience.
Old Jun 19, 2005 | 10:20 AM
nunsa's Avatar
Bad gas mileage?
Rough idle?
She'll only leak so long, as 4crawler said was good advice. If it's leaking from the seals she'll run dry and your HG/heads, pump will sieze..., and a whole boat load of bad stuff! Don't screw around, get that fixed before it costs you more money down the road!
Take Care,
Harry
Old Jun 20, 2005 | 09:49 AM
Flamedx4's Avatar
I've also seen the bearing sieze and the shaft with the fan blade snap off...
If it starts weeping - replace it. No excuses.
Old Jun 20, 2005 | 12:13 PM
Robinhood150's Avatar
And while you're in there you might as well do the timing belt too.
bigjstang
Jun 2, 2025 03:56 PM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
andrewtexas123
Jul 14, 2015 04:29 AM
Avenged
Jul 9, 2015 07:55 AM
coryc85
Jul 6, 2015 04:07 AM
