What to do? Anbody else experience this?
Old Nov 15, 2004 | 10:25 AM
steelhead's Avatar
Recently I have been hearing an odd noise coming from my tacoma. It usually happens in third gear between 25 and 30 mph in third gear. Hard to explain over the net but I can feel it in my floor boards. The odd thing is if I put in 4wd the sound goes away. So I take it to a local dealer and they quickly blame my lift and or a bad alignment, charge me $34 and that's it. I call BS and head down to the shop that does my alignment and the spin the wheels and then we hear it. Sounds like it is coming from the Transfer Case. So i headed home lifted the fron end and drain the t-case. The lube is only 8,000 miles old and comes out clean and beautiful. Refill with regular dino lube (thought maybe amzoil did something?) take it for a spin and the noise is still there. Now I am stuck with fighting the local dealership or taking it to yet another dealer and have them look at it. Any help/suggestions?
Old Nov 15, 2004 | 11:04 AM
4RunnerFever's Avatar
Guessing that its a inner cv-joint and giving you a bump.
Old Nov 15, 2004 | 11:14 AM
steelhead's Avatar
I thought it may be the cv's too but we lifted the front end at full droop and spun the wheels on a spinner and it sounded as smooth as butter. Wouldn't full droop make any noise from a cv even more apparent?
Old Nov 15, 2004 | 11:25 AM
I would think so. Is it possible the spider joints on the driveline are really dry. I hope you realize I'm a no mechanic
Old Nov 15, 2004 | 11:26 AM
steelhead's Avatar
Nope they are well lubed. Thanks for your help though.
ashamsuddin
17
Jul 22, 2024 03:59 AM
primordialbeast117
Dec 19, 2015 12:23 PM
Iceman4193
Oct 16, 2015 10:50 AM
mreagen
Oct 5, 2015 04:27 PM
hiluxinargentina
Sep 30, 2015 05:51 PM
