Weird Jerk/Thump 04 Tacoma.
Old Jun 17, 2011 | 07:04 PM
Kiroshu's Avatar
My step dad has an 04 Toyota Tacoma 4x4 3.4 Auto.
And ever since he bought it about a year ago its always had this weird jerk/jolt.
The truck runs and drives fine and all except for this one slight issue.
(Remember its an automatic)
When coming to a complete stop at a light or stop sign.... its really weird.
Right as you are about to stop when removing your foot off the brake real fast theres a jolt/jerk that seems to come from the rear end off then truck.
Or sometimes when you come to a light or a stop it will stop fine with no jerk/jolt but as soon as you let off the brake to take off its jerk/jolts and kinda shakes a second.
It happens pretty much 80% of all stops... its kind of annoying and i feel as though it could be an issue later on.
I've crawled all under and shook everything down.
Drive shaft, U-joints, and center support bearing tight, rear end has hardly any play. Trans and motor mounts good.
My suspisions are pointed toward the leaf springs. But its a really weird prob i've never seen before and i really need some professional opinions.
However i strongly believe its the leaf springs. Do the springs on these trucks seem to have issues like the later model tacomas?
Old Jun 18, 2011 | 01:56 AM
bicklebok's Avatar
I havent had this problem but have read about it quite a bit on several Toyota forums. Do a search for axle wrap.
Old Jun 18, 2011 | 06:49 AM
tunnelmotor99's Avatar
Does it have rear drum brakes? Might want to look in there and see if something is sticking or otherwise not working right.
Old Jun 18, 2011 | 07:10 AM
toyotacharles's Avatar
I have seen several do this, try greasing the slip joint on rear shaft, could be binding when expanding at wheel lock, the irony is an over lubbed shaft will do the same so dont shoot it until it expands, I usually hit 10 pumps with hand gun and drive it for a few miles doing slighlt aggrerssive stops, if it gets better shoot it again in 500 or so miles and with evey other oil change, certianly can be a cheap fix for a very irratating concern.
Old Jun 18, 2011 | 09:43 AM
lekiboy's Avatar
your cables must be too tight- try loosening the accelerator cable and the cruise control cable...
to see the parts- check this
http://www.toyota-4runner.org/3rd-ge...onse-free.html
but the instructions is reverse as the guys tried to tighten them a bit to improve acceleration...someone possibly overtightened your cables....worth a try.
Old Jun 22, 2011 | 11:49 AM
Kiroshu's Avatar
sorry i have not been replying on my own post >_<.
I did try to grease the slip yoke a long time ago. The was the very first thing i thought it was. I didnt put much grease in it because the gun i had kinda was crappy. but i may try again to see since i bought meh a new gun.
Thing rear brake drag may be the cause? Didn't think about that... Seems odd...
The cable thing would be possible but it doesnt happen when you give it gas or take off... Its right when you stop or let off the brake from the stop.
Old Jun 22, 2011 | 11:52 AM
Kiroshu's Avatar
So i searched "axle wrap" and thats the very second thing i thought it felt like was the leaf springs.... What could cause this axle wrap? Or is it something that is there all the time and the suspension is supose to comensate for it?
Old Jun 22, 2011 | 11:54 AM
Kiroshu's Avatar
I did notice that the tacomas have an oddly shaped leaf spring. Its kinda "bowed" up toward the front.
Old Jun 22, 2011 | 05:12 PM
have you greased the shaft? please try this as i am seeing more and more. in fact i fixed 1 today and 1 yesterday. the springs are slightly bowed, they say it kinda smooths ride. also is it a trd model? there is a tsb for rough ride on that truck that will replace the rear leaf springs if the truck fits in the vin range
Old Jun 22, 2011 | 08:10 PM
BajaRunner's Avatar
I bet U-joints...
Old Jun 22, 2011 | 11:02 PM
Mr.Utah's Avatar
Lube u-joints and slip yokes, if problem comes back soon change u-joints. Ensure your rear brakes are working fine and your leaf spring have not been thrashed.
Old Jun 23, 2011 | 09:16 AM
Rear drums? A leaky rear axel seal or drum brake sticking (saying this as my brakes have done this after getting them fixed from leaky axel seal)
Old Jun 23, 2011 | 11:29 AM
jessed59's Avatar
i would ask a toyota dealer if there was any sort of recall on rear suspension.. my bros 96 runner had a recall an they replaced rear suspension for free hard to believe but hey.. ya never know
Old Jul 5, 2011 | 09:37 AM
afwrestler1986's Avatar
Usually the fix was to put an AAL in there. Axle wrap is caused by weakened leaf springs. How many leaf springs are in the pack? How "leveled" out are they? Does he haul weight on a regular basis? I know a lot of guys in other forums have had this problem and most if not all were fixed with the AAL.
Old Jul 6, 2011 | 02:46 PM
Deuxroues's Avatar
I had the same issue. For me it was the rear drum brakes sticking. I took them apart, cleaned everything up and put a little dab of grease on the backing plate where the brake shoes touch and lubed the adjuster wheel.
Old Jul 6, 2011 | 07:00 PM
ZUK's Avatar
ZUK
Kiro-- Never happens in neutral does it? Only when coming to a stop(usually a fast stop). It's worst when the ac is on? A slow, controlled stop in gear it does not do it.
I seemed to have fixed the issue by installing an antiwrap bar.
Old Aug 15, 2011 | 05:38 AM
melino8's Avatar
im having the same problem with mine idk what it could be
melino8's Avatar
and mines a 04 auto 4dr trd 4wd v6
Davebarbier
Nov 3, 2015 03:28 PM
zombie_barbarossa
Oct 2, 2015 10:54 PM
irv
Sep 29, 2015 01:04 PM
Project90
Sep 24, 2015 11:40 PM
JamesDINAN
Sep 22, 2015 05:37 AM
