Valet Key
Old 10-28-2009, 06:49 PM
portercassidy's Avatar
Valet Key
So I just tried for the third time since purchasing my 4runner, to use the key in the hatch to get the back window to roll down.
Is this because I am operating with the Valet key?
If so, is there a easy way to get the original key?
Old 10-28-2009, 06:50 PM
Yukon's Avatar
You have to hold the key in position for a second or two to get it to move?
Old 10-28-2009, 06:57 PM
I only held it for 10-30 seconds, I will try a fourth time.
Old 10-28-2009, 07:09 PM
Yukon's Avatar
Oh thats plenty long. Must be a key issue. the window move with the in cab switch? If yes, then its probably a key issue
Old 10-28-2009, 07:23 PM
The switch works fine up front, but nadda in the hatch. Whats a guy to do?
Old 10-28-2009, 07:30 PM
98runner210's Avatar
Not a key issue going to be an issue with the switch attached to the key cylinder
Old 10-29-2009, 07:11 AM
BajaRunner's Avatar
If your key works in the glove box, then its the "normal" key. If it doesn't, then its the valet key. The valet key shouldn't even be able to turn the glove box lock.
So if your back window isn't rolling down, its a window motor problem. Have you tried using the switch on the center console to roll it down?
Old 10-29-2009, 02:50 PM
So the key works in the glove box. I guess I have a key cylinder switch issue. I have no idea if I am going to pursue this issue anymore. Unless somebody can give me a really good reason I would want to open my window from the hatch. I dare you.
Old 10-29-2009, 03:17 PM
raydouble's Avatar
It's hot in the summer
Old 10-29-2009, 04:19 PM
BajaRunner's Avatar
Yeah I rarely drop mine down anymore . .. The old 1st gen runners ... you had to actually roll it down to drop the tailgate!!
Old 10-29-2009, 04:25 PM
4Yoter's Avatar
^^^ and second gens
Old 10-29-2009, 07:15 PM
I use mine a lot when camping at the coast. I don't want crap to fall out after the 200 mile drive then 30 miles down a rough 4x4 only beach. I just roll the window down to grab my tackle box or whatever.
83yotastockR
11
11-10-2015 06:54 AM
zombie_barbarossa
10-02-2015 10:54 PM
PNW94Runner
09-29-2015 02:55 PM
JamesDINAN
09-22-2015 05:37 AM
JHalcyonM
09-14-2015 01:10 AM
Quick Reply: Valet Key
