URD SuperGrip Crankshaft Pulley for 3.4L Toyota Trucks
#61
Originally Posted by mastacox
So this pulley essentially helps you put more power to the wheels by slowing down your accessories. The problem I have with this is that your accessories will not work as well at low rpms, such as your power steering, AC compressor, or alternator. I would prefer to keep all of my accessories running at full speed, to help with battery charging, steering effort, and AC coldness...
If I had an extra $300 I would buy it and take it with me when I get my timing belt done.
#62
Substantial weight reduction 2 lbs 10 oz down from 10 lbs stock.
? Freed up acceleration horsepower and torque.
? Snappier throttle response.
? ***********Stock belt drive diameters.***********
? Maximum traction URD SuperGrip design on the supercharger belt drive.
#63
A lighter pullley will not give you gains of 20hp, only in your throttle response and how fast the engine revs up. For a given RPM between a stock engine and one with this pulley on it, the HP will be the same.
EDIT: OK, so i did the calculations my self, because that's the only thing I trust
The horsepower gains are seen in less rotating mass, but only when you ENGINE is accelerating. The faster it is accelerating (I.E. RPM/s) the more gains you will see. So when you're going 4000rpm/s, at 5000rpm (approaching red-line in 1st gear) you will see about 19HP (by my calculations anyway). But what about 3000rpm at 2000rpm/s? You gain 6hp (more realistic driving conditions). Basically, you may see some gains if you drive like a bat out of hell all of the time. Otherwise, the gains are pretty small. It's important to note that the higher the gear you are using, the less gains you see because your engine is accelerating more slowly.
#64
I understand this doesn't give you any more horsepower. But I do want to know what the 'seat of the pants' feel is with this thing installed and you're trying for a nasty 0-60 launch I, like others, am waiting for someone to come along and say "After I installed my pulley, I felt an instant difference in acceleration!"
#65
EDIT:
How fast is a standard Taco or 4Runner going in 1st gear at 1500rpms and 5500 rpms anyway? Anyone care to test? What about timing how long it takes to go between the two?
#66
The Dyno tends to be a real heartbreaker that way
I think this pulley will mainly have gains in engine throttle response, and MAYBE a little in top-end 1st gear acceleration.
#68
#69
There are too many pages on CT to read through during the day - especially when the install hassle (not to mention cost) will keep me from going this route. I don't think anyone has posted numbers. but reading all the threads will give you anecdotal evidence to reliability and seat of pants feel.
#70
#71
The sheer mass of the system requires hundreds of pounds of rotational acceleration (or is it angular velocity?) before you even add the weight of the vehicle. Maybe not - not a physics major I'd still buy it, but only if I start excreting money
voiddweller
19
05-02-2016 09:10 PM
FS[PacNorWest]: T100 auto trans/tcase - Bay area, CA
94whiterunner
09-22-2015 07:25 PM
slacker
13
09-06-2015 06:14 AM
