Turn signal/Brake light wiring question - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 07-28-2004, 10:10 PM   #1 (permalink)
pfdaxe's Avatar
Does anyone know how I can wire the turn signal to my brake/tail light on my 2000 Runner? I'm doing something custom on my rear lights. I already tried connecting them together by tapping the turn signal into the tail/brake and it all works fine until I hit the brakes. Then the turn signal stops and the light stays steady. My question...is there a way I can get this to work with some sort of relay or something??
TIA
Paul
__________________
My 2000 TRD 4 Runner
My email
pfdaxe is offline
Old 07-29-2004, 06:36 AM   #2 (permalink)
Unhappy99's Avatar
Assuming you don't have the factory trailer wiring, or that its bad, the simplest and most cost effective solution is to go to an auto parts store, Uhaul, or kwikhitch and get the harness and converter.
$35 or $40 solves the problem.
__________________
03 Dodge Ram 2500 CTD...its amazing
Ex: 1999 4Runner JT3HN86R1X0199261...Now somebody elses Karl Malone Toyota 'Certified' POS
Legendary Toyota quality is exactly that: A thing of legend.
Defective fuel gauge - 'Certified'
Defective brake rotors - 'Certified'
Defective axle seals - 'Certified'
Defective heater diverter - 'Certified'
etc. etc. etc.
Unhappy99 is offline
Old 07-29-2004, 07:55 AM   #3 (permalink)
pfdaxe's Avatar
Thanks for the reply...but I'm not talking about trailer wiring. I'm talking about the tail/brake/turns on the truck itself.
Unless your talking about adding a harness between my factory trailer wiring and my lights on the truck?
__________________
My email
pfdaxe is offline
Old 07-29-2004, 09:32 AM   #4 (permalink)
Unhappy99's Avatar
It accomplishes the same thing, which is converting your independent turn and brake signals to a combination brake-turn signal. Or did I misunderstand your original question?
This cannot be accomplished by one relay. You need an 'exclusive or' gate (CD4070) driving a PMOS power transistor to switch voltage. This is exactly what the trailer converters do, with some added short and/or reverse circuit protection.
If you have the factory trailer wiring, then just disconnect your brake light wire and attach the trailer wiring brake/turn wire to your brake light. Done!
__________________
etc. etc. etc.
Old 07-29-2004, 09:53 AM   #5 (permalink)
pfdaxe's Avatar
I understand what your saying and it makes sense. I looked under my truck and I have a plug to connect trailer wires to(yellow, green, brown and white)labeled ground, brake, L turn, & R turn. Do I still need the converter and then splice into the wires that come out of that or are these wires already converted?
__________________
My email
pfdaxe is offline
Old 07-29-2004, 10:03 AM   #6 (permalink)
Unhappy99's Avatar
Nope. If you have the external wiring plug, then you already have the converter, lets hope it still works. Just open up the left rear interior panel and adjust your wiring accordingly.
This thread has more info. Start reading about 2/3rds the way down where the photos are.
__________________
etc. etc. etc.
Old 07-29-2004, 10:18 AM   #7 (permalink)
pfdaxe's Avatar
Awesome! Thanks. I'll try it this weekend
__________________
My email
pfdaxe is offline
Old 07-29-2004, 10:24 AM   #8 (permalink)
Unhappy99's Avatar
"to(yellow, green, brown and white)labeled ground, brake, L turn, & R turn."
This should not be the case. It should be:
White: Ground
Brown: Tail lights
Yellow: Left Turn/brake
Green: Right Turn/brake
__________________
etc. etc. etc.
Old 07-29-2004, 03:52 PM   #9 (permalink)
pfdaxe's Avatar
White: Ground
Brown: Tail lights
Thanks...I know. I just typed it as I remembered the colors, not the correct location. It's labled on the plug anyway
__________________
My email
pfdaxe is offline
Old 07-30-2004, 10:44 AM   #10 (permalink)
pfdaxe's Avatar
Ok...this is what I have so far:
I have everything listed as in the other post as far as having the converter and the correct wires.
I cut the turn signal wires completely and left them alone.
I then cut and spliced the green w/white stripe (brake light wire from bulb) into the yellow from the converter.
I then cut and spliced the same color wire on the RT side to the green wire from the converter.
Here's what I have. Brake lights, turns, hazards and tails work fine. My issue is now when hitting the brakes, all it does is flash faster when I have the turns on....
...soooo....I know I'm missing something here or have my splices and/or cuts wrong??
__________________
My email
pfdaxe is offline
Old 07-30-2004, 01:05 PM   #11 (permalink)
Unhappy99's Avatar
So it all works correctly, right? Except that turn signal flashes a bit faster when the brakes are on?
This would be because power for the flashing bulb is coming from both the brake power feed and turn power feed. There is a current sensor in the turn signal power feed, not enough current draw, and it flashes faster than normal, to let you know it thinks you have a burned out bulb.
Solution? Hmmmm....attach a second bulb or power resistor in parallel with your existing bulbs to increase current draw. 10 to 20 ohms and 10Watts would do it. Not graceful, but would work.
I would be inclined to try a 6 amp diode or two in series with the brake power feed going into the converter. Then the preferred current path would be from the turn signal power feed. The brake lights would be a bit dimmer, about the same as they are when the engine is not running.
I don't know if there is a current sensor on the brake feed, if so, then adding a diode or two in series might cause a failed brake light indicator to come on, if there is such a thing on the 4Runner.
Or, just live with it....
p.s. Could also try replacing the flasher with a different one. Autozone sells them for $8 or so, and it may have different current sensing characteristics.
__________________
etc. etc. etc.
Tags
auto, automotive, brake, circuit, converter, current, draw, fuel, gauge, light, protection, signal, taillight, toyota, trailer, turn, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
parking light ,turn signal wiring question mean green General Vehicle Related Topics (Non Year Related) 2 07-13-2007 11:53 AM
Introduction & Brake/turn signal question. WYScott General Vehicle Related Topics (Non Year Related) 0 01-21-2007 12:19 PM
arb turn signal wiring northfacer581 95.5-2004 Tacomas & 96-2002 4Runners 1 09-17-2005 10:36 AM
TJM turn signal wiring. Splice or plugs? goldtaco9 95.5-2004 Tacomas & 96-2002 4Runners 2 02-03-2004 06:30 AM
2009 InternetBrands, Inc.
