Trying to Mount winch by saterday (need help!!)
#41
thats what I was getting at it, even the operation manual isnt enough...
have leather gloves, good thick ones.....
when your winding it back, use the gloves and the little red loop tage that should have been on the hook... its not for show...
when on a winching load, open your hood, and stay away..
when on a load carry a heavy wool blanket, old carpet or if you dont have anything lean a stick on the line when winching, if it breaks it will help to disappate energy (you hope)
pre stretching cable = take it somewhere you can pull the line out (keep at least 5 wraps of cable on the drum) hook it to something, and use your ebrake (parking brake) a few notches to create a load, and winch it back in....
IF your box gets wet... when you have time, use your winch to warm it up and evaporate the water in your box... (corrosion is NOT your friend in that box. try not to submerge your box.
#42
I've actually already removed the entire regular line from the winch. So now I just wrap the sythetic around the drum (5-6) and then bolt it to the winch?
Then I run the line out and tie it to something, Pull up the hand break, put car in neutral and pull the line in.
Thanks for the tips on the solonoid box. Fortunatley 4wheelparts gave me an extra "no matter what" life time warranty free with my purchase. So hopefully I'll be ok. But I will one day relocate it to the engine bay.
#43
Here is a site w/ alot of info.
http://www.wittenburg.co.uk/OffRoading/index.htm
and another
http://www.pirate4x4.com/tech/billav...ery/index.html
The second site is my first recommendation. HTH
and another
#45
and another
and another
thanks
#46
Originally Posted by sdastg1
Wait I got the synthetic line. So I still have to take these precautions? I thought it was supposed to be a lot safer?
#47
Winch cable
I've used my winch to pull a metal building on 4x4 skids. I probably extended 90% of the cable and then reeled the sucker in. Now my cable is back on the roller, just not all nice and pretty and neat. It's not in knots or anything, just not pretty like it was originally when I got it. It was already nicely rolled up/on. Any reason to take it back out most of the way and get it rolled on there nice and neat again or is it fine like it is?
#48
#49
ok everything is mounted up and I've got one end tied. But when I hit the button nothing happens. I've got both the cables hooked into the battery. The small negative cable I've got attached via a screw to the metal frame. What am I doing wrong?
#50
On the 3rd Gen 4Runners the frame is not grounded to the body or battery.
Attaching that little black wire to the frame is not going to make it work right. You have to attach it to the truck body or the negative battery terminal.
Gadget
Gadget
#51
wwwoooohhoooo ropes on. Scratch one more project of the list before tellico.
Thank you very much everyone. And since I've made every possible mistake possible, this thread should be a good write up for anyone else in the same shoes.
thanks again
thanks again
#52
#53
How do you guys keep the rope in place? I thought about leaving the clevis attached and then hang it from one of the d-rings on the bottom. But it will just come right out, and drag along on the street.
#55
The rope sticks out from the front of the bumper. Where do I tie it up to?
I've seen a few pics of people hanging it off their recovery points (mine are two D shaped rings) via the hook that came with the winch. But won't it come right off when I hit a road bump?
justdifferentials
14
06-11-2017 08:36 PM
justdifferentials
09-05-2015 06:52 PM
