Transmisson Fill/Drain Torque
Old 09-25-2003, 02:28 PM
dbullock15's Avatar
Just replaced the transmission fluid (5-speed) in my 2003 Tacoma with Amsoil....I definately notice a difference in shifting, I am quite surprised.
Does anyone know the torque spec for the drain and fill plugs. I snugged them up but don't wanna go too tight.
Thanks
Old 09-25-2003, 02:51 PM
rimpainter.com's Avatar
I torque mine to somewhere between 16 and 20.
Old 09-25-2003, 03:04 PM
keisur's Avatar
I torque mine until it smokes and then I give it another 1/8th of a turn.
Old 09-25-2003, 03:25 PM
MTL_4runner's Avatar
you're always good for a..... or 2
Old 09-25-2003, 07:13 PM
keisur's Avatar
but really, I did this to my rear filler plug, like an idjit. so I had to drill and tap a 1/2-13 thread in the middle of the plug and temporarily put in a nylon bolt. 3 weeks ago when I pull my 3rd to replace it with the new one with 4.88's and an ARB locker, I got it out with a big screw extractor on my air impact wrench. trust me, the worst feeling is knowing that the only fix is to pull the third and tap it a few times from the inside so the screw extractor will work, fill it through the axle tube which means pulling an axle, or tapping a hole like I did. But you're right, I was just trying to get a laugh above.
On topic: My Haynes (Haynis - because I hate it) Manual says 23 ft-lbs on the filler and drain plugs.
Old 09-26-2003, 03:28 AM
dbullock15's Avatar
Thanks guys. They are torqued with my calibrated arm right now with no leaks but I suppose I'll put a torque wrench on there just to make sure.
Old 09-26-2003, 09:27 AM
I use the 2 finger torque method. Put your thumb on the head of the ratchet and only use 2 fingers to apply torque. You can crank all you want becuase unless you are schwartzenegger you won't have enuf strength to over-torque anything and strip it out.
A torque wrench obviously works best if you have one.
....most of the time I am just lazy and my method works for me.
Old 09-26-2003, 12:10 PM
JSharp's Avatar
Hmmm. I always heard you should tighten things until they start to get loose again, then back off 1/4 turn...
Old 09-26-2003, 09:14 PM
keisur's Avatar
yea. I heard that once too. you can also torque it until you see the bolt head start to expand where it is contacting the diff so it looks like a tapered hex.
Kamaloha
10-16-2015 05:13 PM
JUICE222
10-13-2015 08:50 AM
bigtoy83
10-03-2015 06:09 AM
sonorn67
09-19-2015 05:39 PM
larrys93pickup
09-17-2015 07:05 PM
Quick Reply: Transmisson Fill/Drain Torque
