Transmission questions
Old 11-19-2003, 01:10 PM
joegee1773's Avatar
- I have a 1988 Toyota 4x4 with a 4 banger and a five speed transmission. When I baught the truck I was told, by the guy I bought it from, that the transmission would need to be replaced. I don't know why he thought this, I didn't think fast enought to ask him. The truck has 295,500 miles on it and runs good. the only problem I've noticed with the transmission is that when down shifting you almost have to come to a complete stop to get back into first gear. I was wondering if there were any signs I should watch for and/or thinks I could check to know if my transmission is on it's way out. I'm going to be moving in December so I would like to get it figured out before then, so that it doesn't die going down the high way with all my stuff loaded up in the back.
- I've checked local junk yard for a replacement. I have had no luck finding anything that would work. Does anyone know how hard, how much, and where I would get the parts to rebuild a transmission like this. Or somewhere I might find a transmission.
remember I'm a broke college kid so I'm trying to keep it cheap.
Old 11-19-2003, 04:17 PM
Erich_870's Avatar
I had almost the same problem you do in my 87' 5 speed, but mine was a totally screwed up clutch. I couldn't get mine into first gear if I don't shift as I crept to a stop at a light. Then of course I would have to sit with the clutch in. I had my clutch replaced and the mech. was shocked how it wasn't right, I don't remember how he tried to explain it, but it was something like my clutch wasn't screwed down flat, so it as rotating, touching the whole time. Anyway, you might want to check your clutch out, atleast before you go and buy a new transmission.
Old 11-19-2003, 04:57 PM
cabbage's Avatar
Couldnt shift to first??... I thougth it was a protection so you wouldnt shift into first when your moving...
Old 11-19-2003, 06:08 PM
joegee1773's Avatar
I think you're right. My other Toyota doesn't go into first until you slow down to less than 5 mph. But with my truck is basiclly a complete stop.
Old 11-19-2003, 08:02 PM
cabbage's Avatar
Yea, if you want it to go into first you can rev up the engine speed and when they are the same, it will go in easily.
Old 11-19-2003, 08:06 PM
Fink's Avatar
As far as a salvage yard, www.yotayard.com would probably have something you could use...they are nice people.
Fink
Old 11-20-2003, 03:56 AM
MTL_4runner's Avatar
Could be either the clutch not disengaging or the gear synchros.
Very tough to say anything without driing the car.
Old 07-23-2012, 10:46 PM
61unibody's Avatar
i have a 1988 2wd toyota pickup with a 22r and the transmission is going out of it, i found a 1989 2wd toyota pickup with a 22r and i was wondering if i could take the transmission out of the 89 and put it into my 88. can anyone tell me if this is possiable?
chuckross1957
06-28-2019 10:19 PM
mskalmus
05-28-2017 07:51 AM
mYnAmEiSmUd
07-20-2015 06:48 AM
jjrbus
07-17-2015 07:06 AM
Poncho0206
07-10-2015 06:21 PM
Quick Reply: Transmission questions
