which transmission line heads to the tranny cooler?
Old Jul 27, 2010 | 04:04 PM
hdoggie24's Avatar
When looking from under the front bumper, you can see the 2 steel transmission lines. Can someone tell me which line (the left or the right) is the line that sends the oil from the tranny to the cooler. Thanks, would help me out.
Old Jul 27, 2010 | 04:13 PM
kball's Avatar
Check this pic. I believe the send line is the outside line, on the left when looking back from the front of the truck. So the inside line is the return.
Attached Thumbnails which transmission line heads to the tranny cooler?-transmission-cooler-lines.jpg
Old Jul 27, 2010 | 05:08 PM
J2F42C's Avatar
Left one.....
Old Jul 27, 2010 | 06:52 PM
hdoggie24's Avatar
cool. thanks just wanted to double check on that. just finished up my tranny cooler install and i was pretty sure i hooked it up right. thanks. i know have piece of mind that my tranny will never get the milkshake crap.
Old Jul 28, 2010 | 05:38 AM
Rock Slide's Avatar
Good to hear you got one installed. Tranny milkshakes are 2 thumbs down.
Old Jul 29, 2010 | 05:56 AM
gdutch's Avatar
+1 on that. What kind of cooler did you put in hdog?
Old Jul 29, 2010 | 08:39 AM
bootown's Avatar
Aren't these contradictory?
Attached Thumbnails which transmission line heads to the tranny cooler?-bypass.gif   which transmission line heads to the tranny cooler?-cooler_09.jpg
Old Jul 29, 2010 | 08:53 AM
J2F42C's Avatar
Yes they are, the second pic is mislabeled. If that is the case, that Magnefine is not working as well as it could be for the flow is going backwards....
the1998sr5
15
Jul 14, 2020 08:35 PM
mskalmus
May 28, 2017 07:51 AM
BeMiceElf
Oct 10, 2015 09:40 PM
Coreyr384
Jul 10, 2015 11:13 AM
madxman21
Jul 9, 2015 10:26 AM
