Transmission diference?
Old 11-08-2005, 11:28 AM
JEDI87's Avatar
I have a W56 tranny in my 87 runner.I had a 94 standard cab truck with a 22re and 5 speed.Were they still W56's in 94.I had the same lift,gears,and tires on the truck and it started off the line smoother than my runner,even with the top off (weight).I want to swap out the tranny cause it is whining and I wasn't sure if the trucks trans was geared lower or something.Anybody know?
Old 11-08-2005, 12:42 PM
4Crawler's Avatar
Yep, W56s used for all the 22RE equipped trucks:
- http://www.marlincrawler.com/trans.html
Difference is W56A/B are top shift t-cases and W56C/D are forward shift.
Old 11-08-2005, 01:58 PM
JEDI87's Avatar
So I probably have/had the a/b since the shifters were on top of the t-case right?The tranny was the same though?I don't know what the diff is really/
Old 11-08-2005, 02:16 PM
4Crawler's Avatar
Probably, look at the link I provided above, there is a section at the bottom with pictures and distinguishing features off all the W56 trannys.
Old 11-08-2005, 03:00 PM
JEDI87's Avatar
Oh thanks,I didn't look down that far.As far as I can tell I have a w56/c,maybe somebody replaced it already.
TheBFA
02-15-2020 06:55 AM
Rerun
3.4 Swaps
10-01-2015 12:24 PM
Odin
09-26-2015 06:56 PM
toyotasaurus
09-24-2015 03:30 PM
briholt
09-20-2015 10:26 PM
Quick Reply: Transmission diference?
