For those with a wide band A/F gauge
Old 12-13-2007, 02:54 PM
mt_goat's Avatar
When idling have you ever noticed a fluctuation in the A/F when stepping on the brake? Mine will settle nicely around 14.7 then when I step on the brake it instantly shoots up to about 15.5 or so, then it over corrects to about 14 then resettles on 14.7. Then when I release the brake it fluctuates all over again.
I'm guessing its from a change in the vac pressure (due to the brake booster) effecting the URD FTC pressure sensor.
Old 12-13-2007, 03:29 PM
Ian Rogers's Avatar
goat I am still stock with a LM1 in my truck, i see the same flux. when the brake booster spins up it is leaning out the truck. It has nothing to do with the FTC as you are in closed loop when idling
Old 12-13-2007, 04:14 PM
mt_goat's Avatar
Oh thanks, I feel better now.
ashamsuddin
17
01-13-2023 03:17 AM
kawazx636
10-06-2021 03:03 PM
zanzabar0
10-11-2015 02:56 AM
Jdgarrison
10-01-2015 05:22 PM
dbollier123
09-29-2015 05:23 PM
Quick Reply: For those with a wide band A/F gauge
