Last edit by: IB Advertising
Browse all: Toyota 4Runner Cooling System Guides
- Toyota 4Runner 1996-2002: How to Replace Thermostat
Step by step instructions for do-it-yourself repairs.
Thermostat Jiggle Valve?
Just finished up my Timing Belt/Water Pump/Thermostat/etc; and noticed (after the fact) that my FSM says the Thermostat should be installed with the Jiggle Valve in the lowest (6 O-Clock) position. I did not pay any attention to which way it was pointing when I installed it. Just for the heck of it I also checked my Haynes Manual; it says the Jiggle Valve should be installed in the highest (12 O-Clock) Position.
Does anyone know what the function is of the Jiggle valve; why it matters what position it is in when the Thermostat is installed; and which is the proper position; when installed; the FSM or Haynes??
Thanks;
Mark
Thanks;
Mark
The valve allows trapped air to escape when the cooling system is flushed or broken open and drained. The trapped air is a serious problem creating hot spots and eratic sensor behavior. There are reports that the air is hard to remove without the valve. Since air seeks vertical height in water, I would be comfortable with the valve at 12 o'clock but I personally don't think it matters.
My$0.02
My$0.02
I've seen it installed both ways (12:00 and 6:00) and neither seems to affect the operation of the vehicle or the cooling system. That being said I always install mine at the 12:00 position or close to it.
Thanks; I'm going to drain the system and re-install the new T-Stat with the valve at 12:00.
What got me wondering about the whole thermostat thing; is I reached down to feel the lower hose a couple times after the engine was at normal operating temp (about 1/2 way up on the dash temp gauge); and the hose is always cool. I've driven about 50 miles on the new Thermostat; no other signs of running hot. I'm wondering if my new thermostat (toyota brand) is functioning. Going to test it tomorrow in a pot of heated water.
Mark
Mark
Mark
Mark
I always put mine at 12 oclock as well. Some people cut them off when they want their motor to run a little cooler. (dumb) After you put it all back together and run it, let it sit and get cold then just recheck your levels and top off as needed. After that you should be good
I'd say unless you are overheating, your system is functioning properly.
I've checked the lower hose after quite a bit of mixed driving (City/Interstate); no signs of running hot at all; but it still stays cool to touch. It has been cold here since I did the work on it last week; highs in the +10 to +20F degree range; lows down to -10F at night. If the cool lower hose is normal under these conditions; I guess the only reason to reinstall the T-stat is to re-position the Jiggle Valve; right now I have no idea which position it is in.
Thanks;
Mark
Thanks;
Mark
Thanks;
Mark
Thanks;
Mark
_Nicco_
09-21-2015 03:06 PM
LotOMiles
09-14-2015 11:45 PM
