tacomas turn to act up now...:(
Old Feb 9, 2005 | 05:44 PM
Jared Ajlouny's Avatar
the tacoma has been acting a little weird, i first noticed it on the way to hollister with the group on saturday. first problem.... in first second and third when i hit the gas (normal presure) there is a weird "click" than when i let go...same sound. it not only happens when i shift, but if i need to slow down and let go of the gas pedal it does it again...and wheni hit the gas it does it again. i did some testing and it does NOT do it with the truck off when i hit the pedal, and it does not do it stoped at a light with the clutch in. it sounds like it is comming from the transmission area which is why i think it has somehting to do with the clutch....anyone know?
second problem. when the wheels are turned sharp ther eis a weird noise, it sounds like the bearings in the front. can i re pack them , what could be the problem, thanks!!!!!
Old Feb 9, 2005 | 05:47 PM
dwh91102's Avatar
your clicking sounds like a a u-joint to me
Old Feb 9, 2005 | 05:49 PM
superjoe83's Avatar
check your cv's in the front, you cannot repack those bearings
Old Feb 9, 2005 | 05:57 PM
hamstrungtaco's Avatar
obviously its happening when the force is being put on the drivetrain, think it could be a mount or something my muffler was doing a similar thing until i replaced it, what happens when u do it in reverse?
Old Feb 9, 2005 | 06:02 PM
havent tried reverse...brb let me try it....and i got a new muffler a couple months ago...
does the sound mean my CVs are going? i hope not, the tacoma is not going to be wheeled anymore and it would piss me off to have to pay to replace the dumb CVs!!!!
Old Feb 9, 2005 | 06:07 PM
reverse also......
Old Feb 9, 2005 | 06:26 PM
sounds like a U joint or possibly the linkage to the 2nd driveshaft is all i can think of, does anyone know more about trannys or think it could be the syncros?
Old Feb 9, 2005 | 06:29 PM
its a 5 speed.....how would i tell if it is the drive shaft?
Old Feb 9, 2005 | 06:40 PM
waskillywabbit's Avatar
If you got a bad u-joint in the driveshaft it usually chirps and squeals propportional to speed intervals. You get a click more with the CVs. A bad u-joint will also have a funky dust around it (that you can see on the joint) cause the metal is just grinding in there.
Old Feb 9, 2005 | 06:44 PM
i dont think the "click" is comming from the CVs it sounds more like a tranny/clutch issue....its weird.... so for the bearing sound, what do i do?
Old Feb 9, 2005 | 06:46 PM
<cough> mechanic <cough>
Old Feb 9, 2005 | 07:02 PM
Nic's Avatar
Nic
Engine Mount?
Old Feb 9, 2005 | 07:04 PM
i dont take my trucks to the mechanic!!! if i dont do it myself i never learn!!!
Old Feb 9, 2005 | 08:37 PM
superjoe83's Avatar
grease your u-joints, and if the noise changes at all the thats your problem, and while your under there give the drive shaft a shake, the should be no slop in the joints, there may be some movement in the carrier bearing isolator, but thats normal, make sure to do this with the transmission in neutral and parking brake on to relive stress from the drive shaft, good luck
Old Feb 9, 2005 | 08:59 PM
http://4wheelparts.com/4wp/products/...DR&expand=sub5
will this work on my tacoma.....if im not going to use the 4x4 much i might as well just make it so i can disengage the hubs to not ruin the CVs......
Old Feb 9, 2005 | 09:00 PM
will do tommarow after work, thanks...
Old Feb 9, 2005 | 09:18 PM
superjoe83's Avatar
that kit wont work on tacos
Old Feb 10, 2005 | 06:40 AM
thats what i thought.....i would have to take the hubs and everything from a taco with it..correct?
Old Feb 10, 2005 | 09:44 PM
superjoe83's Avatar
yes, pretty much from the diff out gets swapped
Old Feb 21, 2005 | 07:26 AM
ok, i lubed the Dshafts and itis still making the noise. i put my finger in the hole where the clutch is and i felt a paperclip type metal peice, when i moved it it made the noise i was hearing. also in reverse it randomly vibrates and i hear some noise....its soooo hard to describe but its bugging the crap out of me.......someone has had to of gone through this before!
Hiluxtrucha
Jul 22, 2015 10:00 AM
94yotaMI
Jul 21, 2015 05:47 AM
Hamonacracker
Jul 17, 2015 08:33 AM
94whiterunner
Jul 12, 2015 07:15 PM
Poncho0206
Jul 10, 2015 06:21 PM
