Switch to manual hubs from ADD Question
I did a search and could not come up with an answer. So here goes. When you remove the cap covering the ADD hub. There are the bolts to remove the hub then one more under the little gold cap thing. Correct me if I am wrong on that. My question is how do I remove the gold cap?
The one about the size of a quarter that has the single bolt in the middle of it? Just pull it off, only thing holding it is it's stuck to the grease.
If you mean the hub, after the cone washers are out, pry it off with a screwdriver.
icentropy
07-14-2015 10:23 AM
