| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
__________________
2001 2wd 4runner Limited 5VZ-FE V6 auto Thundercloud Metallic ISR+Deckplate-Done! |
#2 (permalink) |
daystar lift is probably the right one for you. it is 2.5 though but i dont think that half an inch would be much of a differnce for you. not sure though about the poly vs. alum.
__________________
'01 Toyota 4Runner Limited -------------------------- Mods Listed Here:My 4Runner |
#3 (permalink) |
I would just replace the springs with some stock height replacements. Spacers will solve the bottoming out on the bumpstop problem but its not going to fix anything as far as functionality of the suspension, especially if you plan to tow a trailor. Your 150 pound brother will still bottom out the spring only difference is, there will be a spacer keeping the axle and bumpstop from touching. Just a thought
__________________
1986 4runner 31" mt's aftermarket shackles Custom front bumper/winch Light bar/auxilary lighting Rear Detroit future mods: 33's maybe 35's, 5.29's, Rear bumper with tire/jerry can,highlift mounts, sliders. Conquer with the IFS until I can't conquer anymore and then do an SAS. Last edited by hurley842002; 04-06-2008 at 08:26 PM. |
#4 (permalink) | |
Quote:
#5 (permalink) |
The 01-02s are lowriders to begin with. The front only has about .75 to 1" of downtravel before I am into those bumpstops. Just a quick search of ebay comes up with a four corner spacer lift for $130 shipped.
__________________
#6 (permalink) |
Monroe MA700 air shocks $65
http://www.yotatech.com/f31/potentia...-shocks-60181/ http://www.yotatech.com/f2/air-shocks-61213/
__________________
88 4Runner. 350 V8, R150 5-speed. SAS, 36" TSL's, elocker rear Last edited by Adam F; 04-07-2008 at 01:55 AM. |
#7 (permalink) |
it's really up to you and your budget. to me spacers would only band aid the problem even if that. more like ointment and no band aid. any ways it would raise it up but who knows if it would really stop the problem, especially if you say you're planning to tow. if its true that a 150lb guy bottoms it out on dead weight then i would suggest changing the whole spring because the old one is shot.
__________________
98runna lifted and locked. |
#8 (permalink) |
After a little more thought and research, I found some 2" rear lift coils from WabFab, and some 2" alum spacers up front.
__________________
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| wheel spacer questions | captain_howdy | 86-95 Trucks & 4Runners | 8 | 02-05-2008 07:03 PM |
| BJ Spacer+Cruiser Coil Lift Tire questions | traben27 | 86-95 Trucks & 4Runners | 3 | 03-27-2007 08:26 AM |
| Coil Spacer Questions | Jeeperman | 95.5-2004 Tacomas & 96-2002 4Runners | 6 | 09-28-2006 08:03 AM |
| SDORI B.J. Spacer Install questions... | 4Runner 4Play | Offroad Tech | 12 | 09-08-2006 11:50 PM |
| spacer lift: topout extender vs preload spacer | Rishi | Offroad Tech | 15 | 04-17-2005 05:18 PM |
