Still having problems:
Old 03-08-2004, 07:37 PM
obxfishn's Avatar
I am still having a vibration at around 25 mph and it feels like its coming from the front end. I had a 3" suspension lift installed back the first part of January and when my speed is decreasing to around 25 mph there is a vibrating feeling under my truck. I have had an alignment and I have packed the u-joints with grease and the CV angles look like they have a slight increased upward angle from the tire to the diff, and I have a diff drop installed and this is getting on my %#&@ last nerve. Any more ideas. I am at a stand still for thoughts.
Old 03-08-2004, 07:45 PM
fooddude's Avatar
is there mud anywhere in your wheels or brakes. I had this happen after i went mudding, so i washed the wheels out and the brakes too and it still did it. Turned out there was just a little bit of mud making the whole thing vibrate.
Old 03-08-2004, 09:51 PM
toy283's Avatar
It's possible your front driveshaft is out of balance. The increased angle of operation after your lift will accentuate any imbalance.
Old 03-09-2004, 06:16 AM
obxfishn's Avatar
The vibrations started after I had the lift installed. I have not been mudding since I had the lift put on.
obxfishn's Avatar
Is it hard to re-balance the shaft?
Old 03-09-2004, 04:24 PM
WT
WT's Avatar
One question ? do you still have the factory wheels and tires or have you replaced them ? I would guess maybe there out of balance, guess a quick test would be swap the front wheel to the rear and move the rears to the front see if its any better. I am also guessing maybe you have had the wheels tested for balance. Also when it is vibratng is the steering wheel also vibrating ? maybe a stearing rack problem .. just another guess
Old 03-09-2004, 05:11 PM
obxfishn's Avatar
What potential problems could a steering rack produce?
WildCard22RE
01-03-2018 04:17 PM
Corvoid
12-11-2015 11:21 AM
BrendenD
03-05-2015 10:32 AM
whambamthankyoumaam
08-19-2014 07:16 PM
tyes
02-22-2014 06:39 PM
Quick Reply: Still having problems:
